Cannot detect ECU
jeremylee81
59
I'm using 4G92P fuel injection engine. The Mod i had done on my car that related to ECU only replace my auto gear box to manual G.B without changing to the manual ECU. and also i got a turbo timer that already broken but the wire still connected to the ECU.
my problem is the Mech can't detect my ECU when he use some computer console stuff to detect my ECU and then check my car problem at T.body(tuning after changing new T.Body). but My car seems to be normal as the 'Check Engine' light will go 'Off' few sec after i switch on.
The Question is, why the computer console cant detect my ECU?? is it bcz of not changing to manual ECU and wiring or is it bcz of the broken turbo timer?? need some advice, thanks :cry_smile:
acbc
4,615
8
KD
Is the engine originally from the car or transplanted? If the latter, most likely the diagnostic port is not connected. Seen many Wira to VR4 conversions with incomplete wiring.
BTW, what diagnostic tool ur mech is using? He should be using the right cable too, namely OBD-I not ODB-II (for 1996 cars n above).
jeremylee81
59
He using the right tools, bcz he did run a demo on another car with the same engine as mine, and it really can connect. He even use his second computer console unit to read my car ECU but cant detect anything. but both of the computer console unit can detect the other car.
1 more question, is it replacing the gearbox from auto to manual without changing the ECU and wiring will cause this problem?? bcz from wat i know is auto car got 2 ECU, 1 for engine and another is for auto gear box.
or can it be my car got splash with a lot of water bcz of raining and causing this problem. bcz my alarm siren was not function for few days after driving under heavy rain. but the siren ok already yesterday, after the ECU checking.
need some help here.....thanks.
Watch this video of the Nurburgring inspired, limited edition Astron Martin V8 Vantage N420 goes roaring on the public roads and tracks. The V8 roar is so synonymous that Top Gear did mention that it is one of the most beautiful sound you'd ever hear from a car. Check out this car which is made exactly no more or no lesser than 420 pieces. Enjoy the video...
