Anyone Running Without Thermostat?
manshen
Oct 31, 2013
13
503
I removed my thermostat in order to reduce engine temp. I find that it does benefit provided the engine is tuned to take advantage of it. Cause I find that I can run slightly leaner and advance ignition a bit. Engine also feels more lively.
Engine now runs around 70C instead of 85C.
ken yeang
6,000 RPM
6,617
1,327
Running without the unit is quite common practice in Malaysia -esp. taxi
What is supposed to be your optimum running temperature? Running too low will accelerate wear.
I did run without thermostat in my old car last time but on rainy days it kept at a low temperature the engine was sluggish. I think better off using a lower temperature thermostat.... :driver:
International Platinum Club, also known as IPC International Group was conceived with objective to venture into an era of E-Commerce and M-Commerce where the trend of Information Technology is growing tremendously. On 5th June 2001, it was incorporated and registered under the name IPC Shopping...
