Anyone Running Without Thermostat?
manshen
Oct 31, 2013
13
503
I removed my thermostat in order to reduce engine temp. I find that it does benefit provided the engine is tuned to take advantage of it. Cause I find that I can run slightly leaner and advance ignition a bit. Engine also feels more lively.
Engine now runs around 70C instead of 85C.
ken yeang
6,617
1,327
Running without the unit is quite common practice in Malaysia -esp. taxi
What is supposed to be your optimum running temperature? Running too low will accelerate wear.
I did run without thermostat in my old car last time but on rainy days it kept at a low temperature the engine was sluggish. I think better off using a lower temperature thermostat.... :driver:
My car currently in the workshop because of my current blown engine, now i just replaced it with a new "Engine Kosong"
I also made Wiring transplant from my YRV wiring to Passo Racy wiring.
So im not too sure if its the engine kosong problem or the wiring problem,
What i have troubleshoot :
Ignition coil not responding. ( it has current but its not making any sparks )
Other than that everything is fine
anyone please help me.
