Advice for Rim Off Set
Cheongxp
94
508
Selangor
Dear all Sifu,
I need you guy help to advice :
My A32 was VQ2.5 with 1 way LSD Gear Box.
Previously fixed with Taiwan Rim 17 inch x 7.5JJ off set +38 with install Spacer at rear.
I just get myself at Used Rim with 17 inch x 8 JJ Off Set +35 & take out the Spacer at rear side.
Both rim fix with 215 x 50 x 17, I knew for 8JJ 215 series type was a bit small.
My confuse was below now :
1. The road feel was different for this 2 sets of rims, For the new rim I feel not that Solid from front side & road feel was less especial those uneven road.
2. With off set +35 will it damage my front driver shaft & other things ?
It's A32 with 17 inch x 8JJ Off Set +35 was too much ????
The beautiful Saab Turbo X will be unveiled at the coming Frankfurt Motorshow. Featuring xWD<b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b> (all-wheel-drive system) and electronic limited slip differential (eLSD)...
