The New Proton Waja..2011
passo123
1,013
206
putrajaya/sban
got this on the net....guys...is this true?
here's the specsheet...
4B10
Specifications
Engine type Inline 4 cylinder DOHC 16v, MIVEC
Displacement 1.8 L (1798 cc)
Bore 86 mm
Stroke 77.4 mm
Compression ratio 10.5:1
Fuel system ECI multiple
Peak power 105 kW (143 PS) at 6000 rpm
Peak torque 177 N?m (130 ft?lbf) at 4250 rpm
4B11
Specifications
Displacement 2.0 L (1998 cc)
Bore 86 mm
Stroke 86 mm
Compression ratio 10:1
Peak power 108-114 kW (147-155 PS) at 6000 rpm
Peak torque 198 N?m (146 ft?lbf) at 4250 rpm
Characteristics
The engines?s bore and stroke both measure 86.0 mm, which engineers refer to as square. According to Mitsubishi, the new cylinder dimensions contribute to a free-revving character (6,500 rpm redline, 8000 rpm final), linear power delivery and wide torque curve. Mitsubishi used a timing chain instead of a belt for better reliability, iridium spark plugs to lower emissions and to help extend major service intervals for lower cost of ownership. To reduce weight, Mitsubishi used a plastic cam cover and intake manifold and double-layer stainless steel exhaust manifold. The exhaust manifold has a rear location on the transverse engine, compared to the front location for the previous engine, yielding important benefits such as better emissions performance. To lower vibration, Mitsubishi used a 4-point inertial axis system with cylindrical hydraulic engine mounts on the left and right sides. A lightweight, high-rigidity squeeze-cast aluminium bracket on the right side mount (engine side) lowers engine noise under acceleration. A lightweight, high-rigidity steel plate bracket on the left side mount (transmission side) lowers gear noise. A custom-tuned insulator was developed for the front and rear mounts to help control both idle vibration and acceleration shoc....
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
I see paddle shift....photo is taken inside Port...
yeehau86
Feb 10, 2007
2,856
2,425
The "real" Lancer also have paddle shifts, even the platforms are the same with this model. Can say almost all is the same.
Mrnazmi
510
29
3,028
Drag City
If the new proton waja is true regarding the Mivec engine, then congrate to Proton R&D team la because they just see en evolution in vehicle transportation industry..:proud:
kumar22mostwanted
1,562
152
HELL!!!
wahh if use mivec technology and also have paddle shifters and such awesome features this car would be a major leap for Proton
though i do pity the lancer gt owners as their car secondhand values should plummet
xtremeleo
3,247
464
5,183
how sure are we these photos werent taken before the lancer GT's launch? it looks exactly like the new lancer, isnt the so-called partnership between proton and mitsu has ended ke?
MiTec-i
852
16
3,018
Kay L
www.teamfuze.rules.it
i dun think this is a step forward for proton...this is 2 step backward...utilise the flexibility of the exora platform proton engineers....why pay royalties again?it's a complete reverse cycle. even the saga,iswara and wira,satria putra look way diff...this is almost the same....leap forward?NO WAY!!
toozmok
594
wow....wajah evo again...........:stupid::stupid::stupid::stupid::stupid::stupid::stupid::stupid::stupid::stupid::stupid::stupid::stupid:
Similar threads   Forum
Revanus Introduction and Newbies
DR78 General Talk
News and Features
Y General Talk
A Introduction and Newbies
Wheel And Tyre
Car Modification
News and Features
J General Talk
News and Features
Wheel And Tyre
Wheel And Tyre
Proton
News and Features
Car Talk
Car Shops and Services
  Similar Threads
DR78 General Talk
News and Features
Y General Talk
Wheel And Tyre
Car Modification
News and Features
J General Talk
News and Features
Wheel And Tyre
Wheel And Tyre
Proton
News and Features
Car Talk
hi.. dude.. my car is satria 1.6 auto recently my auto gear box starting to kacao already dont know y.. i change the auto oil and the atf cooling seem ok! after not long ago every morning when start my car if i direct driving go out after start my engine a while i change to d gear then my car will become natural gear.. omg i need at less warm my car around 3 to 5 minutes onli i can able to drive out my car especially in the morning when i need to drive my car to work.. omg! well seen my auto...
