Aiya kawan... do some research first la. Search online, forums, facebook, friends and all before asking generic questions like this. Besides, what is your definition of "most durable"? Usually if it's just hi-lo you won't get serviceable (most cases la).Zerone, GAB, HWL, KYB, D2 etc... budget within 1.5K
my car is ncp150 Vios
thank you sifus
Sounds like you are a newbie, if you research around, you will know there's NO MOST DURABLE adjustable. Our roads here macam hantu, one fine day a new hole may grow and it will kill any adjustable if you hit it at the right angle.Zerone, GAB, HWL, KYB, D2 etc... budget within 1.5K
thank you sifus
Agree with this, relatively pretty cheap yet works well but not adjustable.KYB RS Ultra
ok next.
because any adjustable for rm1500 will be rubbish.Agree with this, relatively pretty cheap yet works well but not adjustable.
Reputable imported adjustables I think minimum rm3k upwards, not sure about local brands.because any adjustable for rm1500 will be rubbish.
yupReputable imported adjustables I think minimum rm3k upwards, not sure about local brands.
Well adjustable is just that, to provide more ability to adjust. Sure you can try to somewhat achieve almost similar performance with a set of sport absorbers and springs but there's often a compromise there. Maybe it's not low enough or too low, damping too soft or too hard, cannot correct camber if necessary in many cases. Using adjustables you can try to get much closer to what you want/need.yup
But TS might think we are arrogant assholes. Just saying you can’t get good adjustable for that kind of money.
And HONESTLY, I see no point in adjustable for pure street driving.
The biggest variable for street driving is not the adjustables... it is the fking road.Well adjustable is just that, to provide more ability to adjust. Sure you can try to somewhat achieve almost similar performance with a set of sport absorbers and springs but there's often a compromise there. Maybe it's not low enough or too low, damping too soft or too hard, cannot correct camber if necessary in many cases. Using adjustables you can try to get much closer to what you want/need.
Actually kind of true, although i got 3 pair of adjustable shocks in my fleet, i only adjust them once or twice during initial setup. A good shock will satisfy any kinds of roads to a certain degree while providing certain degree of improved handling and comfort. Adjustable shock is good when you need to lower your car to a height that you like, as for damper rate, you rarely mess with it. At least that's my usage so far.The biggest variable for street driving is not the adjustables... it is the fking road.
The road is so fked here, you can't adjust your adjustable to perform at its best for the road. For the track, I understand.
Even if you drive the same road everyday, and don't go anywhere else, and you adjust your adjustable for that road. Guess what? Doesn't take that road very long to get fked due to heavy rain, lousy drainage and lorries & bus to fk that road up anyway. What you gonna do? Adjust your adjustable every 3 months? Ok, if you're that hardcore and dedicated, you win.
As I said, you get closer to what you want in most conditions but not necessarily always comply. Note that you now can have Tein active EDFC also which brings damping like adaptive suspension to their adjustables. Now just a matter how much closer you want to your target setup whether you want to spend.The biggest variable for street driving is not the adjustables... it is the fking road.
You meant in Indon ? You would need rally spec thereAs I said, you get closer to what you want in most conditions but not necessarily always comply. Note that you now can have Tein active EDFC also which brings damping like adaptive suspension to their adjustables. Now just a matter how much closer you want to your target setup whether you want to spend.
BTW you're too cynical on MY road conditions, so far I find Klang Valley roads are mostly still pretty good, not as bad as you said. I am used to driving in far worse. Here is just kiddie level compared to where I come from.
Ya la, over there you need softer suspension and thicker tires.You meant in Indon ? You would need rally spec there
TEIN EDFC expensiveeeeeee where got RM1500As I said, you get closer to what you want in most conditions but not necessarily always comply. Note that you now can have Tein active EDFC also which brings damping like adaptive suspension to their adjustables. Now just a matter how much closer you want to your target setup whether you want to spend.
I know, we are talking in general now about adjustables usage on street driving ma, not necessarily tied to the budget anymore.TEIN EDFC expensiveeeeeee where got RM1500
That's the thing, getting the ride height that suits your need is not easy. For me often if just sport springs, they're a bit too low and I wish it's just like 0.5-1cm higher but no more.Actually kind of true, although i got 3 pair of adjustable shocks in my fleet, i only adjust them once or twice during initial setup. A good shock will satisfy any kinds of roads to a certain degree while providing certain degree of improved handling and comfort. Adjustable shock is good when you need to lower your car to a height that you like, as for damper rate, you rarely mess with it. At least that's my usage so far.
If i have another choice, i would go with OEM shaped shock with sport spring and call it a day. Adjustable for street car is somehow under use.
My experience with sport springs they are low enough but runs the risk of bottoming out if you retain stock shock. Usually i will go with sport shocks to pair with it.That's the thing, getting the ride height that suits your need is not easy. For me often if just sport springs, they're a bit too low and I wish it's just like 0.5-1cm higher but no more.
As for damping, I did fiddle around with it many times for many months until I reach my current settings.
Yes that too.My experience with sport springs they are low enough but runs the risk of bottoming out if you retain stock shock. Usually i will go with sport shocks to pair with it.
Actually have to, stock dampers cannot pair with sport spring, different rating. Dampers will damage faster too.....My experience with sport springs they are low enough but runs the risk of bottoming out if you retain stock shock. Usually i will go with sport shocks to pair with it.
I think you need to add another 3K to get a good suspension. I will put my budget at 4.5K to 5K for suspension. 1.5K just don't cut it.Zerone, GAB, HWL, KYB, D2 etc... budget within 1.5K
thank you sifus
Feels like sampanMy experience with stock dampers + shortened springs = boing boing boing boing boing. Sit behind sure vomit. Lucky I can hold on to my steering wheel.
Thread starter | Similar threads | Forum | Replies | Date |
D | To those who own a honda prelude 2nd gen please help! | Car Modification | 1 | |
S | Convert B8T 210 4wd gear box to 2wd! Please Help!!! | Car Modification | 8 | |
D | please help. satria neo (evo engine) | Car Modification | 16 | |
A | Please recommend Plug Cable | Car Modification | 10 | |
A | Modify seat 'bracket' at JB, PLEASE recommend. | Car Modification | 10 |
