Simplest DIY Side Gap
fstr
7,935
954
Sahara Desert
this simple blardy "fcuk urself in the well with 10,000volt" side gap edi done ages ago since batu tiga days laa... whats the problem?
new side gap?? woW i'll be damn...
PocketRocket
'(00) Mod'er
11,164
953
Up Yours
he's the pioneer of everything mah...
now global economic crisis only wanna do side gapping
xD
koie587
1,001
i know bout it but dont know the effect...anybody can let me know the pro & con?...
mokomoko
895
154
Do that mod yourself equals
*cue the song 'the inkspots - i don't want to set the world on fire'
renxun
1,138
37
1,648
long time ago i tired tis. but the prob is the electrod eat side way. have to correct them quite frequent. not too convinient for my 1jz as my coil pack had to be removed in order to access the plugs.and not to mention the plastic cover too .. so many things to open
akuma
3,489
152
Kuantan
just my 2 cents...IF by side gapping,d spark produced is on par w those so-called performance plugs,thn y didn't d manufacturers did it frm d factory?reliability issue?warranty issue?what?
i've never tried dis b4 n i dun plan 2 unless sum1 can vouch 4 its reliability ler............
anyway,whr is dis well w 10,000volts ar?SOMEONE ought 2 b thrown in der,right?HAHAHAHH
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
reliability issue... the electrode will experience wear n tear... this same goes to normal plugs which had its electrode hovers over it... normal sparkplugs with electrode hovering over it has longer lifespan as the gap remains the same even there is wear n tear on the long electrode leg....
on the other hand... for sidegapped sparkplugs, once the electrode leg wears off, the gap widens and u will experience missfiring... if u know how to regap the gaping, it can still be reused... i've been using sidegapped plugs for few years already... each time when i experience sluggish performance, i'll regap the gaping....
akuma
3,489
152
Kuantan
so,dis side gapping REALLY works just dat it'll b a continious "maintenance" on d gapping part,right?
hmmmmmm..............
hi guys, wanna to know about what is weber carb and what is 4 throttle?
i tot both things is the same just the name tak sama oli, but my fren told me that i am wrong. is not same.
so, nid to ask expert here about this. just wan to make it clear about this two things. pls give me more info about this. thanks 1st to u all.
