lowered my car
20V Quard Cam
297
Hi Anyone
Im New Here
Now I Want To Lowered My Car
So I Got To Change My Spring Or Absorber ?
Do Absorber And Spring Play The Same Role Of Lowered Down The Car?
Thx For Answering My Question..
boyzone
2,669
5,148
Actually u are not the first one to question this changing. Since u are new, here some tip for u to lower ur car :
1. Economy lower : changing to sport spring with stock absorber only.
2. Standard lower : Changing performance / sport absorber with sport spring to improve better handling.
3. Pro lower : set up with coilover adjustable kit to maximize lower and handling performance.
P
prolog
Guest
The title is very misleading..
I thought you had already "lowered" your car..
I didn't know you were just planning to "lower" your car.
Anyway, good luck
strangex2
238
If put sport spring still tak puas, then change sports abs loh. One step at a time.
mag9556
2,770
43
1,648
Cut spring will? be like riding sampan later...
change sport spring? will be like riding a mad bull later....bumpee like hell
try to change to shorter absorber where after market have...
if dun u will regret later....anyway what car u drive??
Good Luck....
4ndr3wt1n
6
Hey guys,
I'm driving a wira, is lowering the car and putting on an evo 8 bumper would be a good idea? how bout going up on a bump... anyone know if it sure will hit the bump? :hmmmm:
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
Good Luck....
hahaha...change to short stroke abs, will be like sitting on the skateboard....no spring feels at all...ahahaha...just like mine...:stupid:
mag9556
2,770
43
1,648
skateboard got absorber?? this one dun knoe le.. but what I knoe is short stroke absorber ride will be better only and with ori spring more better thus car look lowered also...
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
short stroke abs,from my knowledge,is to avoid ur abs from bottoming out
if u lowered ur car to much.short stroke is also design that way so that u'll
retain the stroke of the abs even u lowered ur car n finally,it's
design to lower ur car slightly as the spring seat is lower then oem
counter parts.just my 2 cent.
Hi bros, What do you suggest for a set of BBK for suzuki swift using 16" with offset of +38? There are those plug and play 4 pots and mini 6 pots but cost quite expensive. Anyone can share what other alternatives can be use to mod to fix to Swift? currently i have R32 4 pots but not easy to mod as the caliper's bracket interference with the stock swift caliper bracket mounting. Please help bros!! Thank you..:adore::adore::adore:
