DIY spring Stiffener
tigershark1976
61
14
1,508
Anyone know how to DIY a spring stiffener? It is used in between the spring to make it more stiff... to improve braking and handling. I know splitfire is selling but too ex.... around S$80/pair.
For me, I wan to use it so that when going over a hump, my lowered ride wont hit the undercarriage so easily....
ndselvam
68
Dude, i had smae problem my spring abit low so always hit undercariage
Wat i did was
1. I bought 1 meter of rubber hose RM 7 -The Good one got double layer with threads all like the gas hose type-Heat resistant to certain level
2 Slot it in on the lower part of spring for about 5-7 " until u can push max.Use some rubber grease to ease the process
3. Fit the spring back - go for ride and see whether stiff enuff or not- if still not enough do the same to upper part of the spring too
4.If u do this too all four - u ll have less squeking noise and wat i see is car slightly higher and handling still as good as it was.
I user iswara- wat car u use ?
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Hi bro, adding rubber hoses won't stiffen the spring. It acts as a cussion only.
To stiffen the spring, you have to cut it or buy a new set. External reinforcement of spring will tend to offset the characteristics of the spring which is dangerous.
The cheapest way i can think of is, get top and bottom cussion from spare part shop or cut the spring 1/2 coil or both.
ndselvam
68
Cutting the spring goin to make it worst ,Try sloting rubber hose if its cushion properly then it will be hard ..Cutting is the worst idea - instead or buying new one might as well slot rubber the whole spring
up to u to try it - just my idea worked for me
unknown1x
369
2
cut spring = stiffen? where u learn that dude! cut spring = shorten. but not stiffen.. -_- common sense goes wrong !
ndselvam
68
spring stiffener
nicely said - unknownx1
hahahah
xavier
65
Cut spring = Stiffen suspension? Hmmms...
I totally agree! Shortening the spring = Stiffening??? Alamak! More like your ride will be like a boat in the middle of a rough sea! Hahaha! :confused_smile:
cheewooi
25
5,003
Serdang
How to slot the rubber host in? I am driving Wira, do we need to dismantle the suspension and slot it in? Or we can just do by jack up the car and remove the tires?
tigershark1976
61
14
1,508
I think the gas hose is a good idea... cutting the spring?? I agree with most bros here... it'll do nothing but risk your life only!
ndselvam
68
Im not sure how is suspension system is configured either independant or like separate.anyway here how to do it-
1-JAck up the car
2- Remove the absorber ,take out the springs.
3- Put some rubber grease on the spring -Slot in the rubber for about 5-10 inch as much as you can
4-Fit everything back - Do alignment again
5-If you do no how to do - PM me ill intro my mechanic to u - he is good and this stuff and - reasonable price for me he charged RM 30 including the hose about 1 hour plus job -
NoMercy
254
3,018
according to physic theory, shorten a spring will actually increase the cuted spring rate, so is = stiffening. Can refer to form4 physic on that.
about the proble of 'middle of rough sea' actually alot of ppl din notice dat after change to a shorter spring or cut spring will reduce ur shock travelling distance, meaning to say that the gap ur car can play taking the bump stop(rubber thing that slot into the shock rod) into account is actually lesser than original and too little until u hit the bump stop every time ur shock start to travel.
if dare to cut the bump stop, the ride will be better, but ready for a hit under carriage or fender if u carry lot of ppl in ur car as ur car got a lower ride bottom height limit d.
back to the question of this thread, rubber hose will help if is on a progresive type of spring, but it will eventually contra with ur main aim of lowering ur car, now u r permanently putting it up a little again. anyway jus my 2cent input, no offence to anyone.
xtorm
1,590
49
ever check out tose taiwan meg? they hav tis rubber to slot in between spring....
i bought 4 spring cushion, duno how u call it, rm8 each, its round and 1" high, they hav few sizes tho, so buy depend on the distance between each round of ur spring.
its O shade, cut it so u break the O shape and slot it between ur spring rounding....
did it on my car, it feels stiffer when pressing it down and take corner better,,,,but feels the road better also :P, hates tose little holes!!! but can take it out anytime
will try to snap a pic so u guys can understand wat im trying to say
nomercy...wow little ppl knows abt the bump stop trick :) muz b a player :P
ygjau
37
F=kx
F= force(N), k= spring rate (N/mm), x=distance(mm)
k is constant, so when x reduce when u cut it, F will increase (means harder to press)
arsenalboi
1,017
selvam any pics? btw good yasui jack usually how much? we all not so loaded to buy workshop car hydraulic raiser lah :)
Hello everyone,
No i'm not puting up pics of the new car but more like curious. A reliable source told me that Suzuki is launching the new Grand Vitara next month. I checked the net, there is no new grand vitara, only the 90s model. So anybody can confirm whether there will be a new Suzuki SUV launching next month?
ATT: can the moderator please help me move this to Car Talk, thanks!
