Are Lightweight Rims worth the investment?
sweelt
Nov 6, 2016
2,306
248
thanks all.
I'm looking at advanti rims because most aftermarket lightweight rims do not have pcd 4 x 114.3 which renders limited choices.
have you all heard from Kean Lee Hin store at jalan ipoh, which is one of the authorized supplier for Advanti rims?
Will the gap between the fender and the tyre look weird with aftermarket lightweight rims?
Take ur time if u really interested with aftermarket.
But not much fancy choices for 4x114.
Took me 3 mth to search for right ssr type-c 4x114.
DNGFashion
95
14
508
where to b
where to begin with since, I only know about Kean Lee Hin?
Hmm I think that should not matter much if at all as long as the rolling diameter is about the same. Weight on the other hand plays a significant role.
that's my point la. rolling diameter is 5% different.. haiyo.. ok let's just drop this chain of thought already
You bough ori? Can teach how to see if ori or not?
Bro, you're wrong, wheels diameter is different but rolling diameter in that video 2 is NOT 5% different! As I said earlier, the 18 is actually 1% bigger rolling diameter yet generates more whp.
In video 3, one of the lighter rim is also exactly same diameter and tire size so again exactly same rolling diameter.
sweelt
Nov 6, 2016
2,306
248
Ori or not...susah to differentiate just by look.
Like mine ssr type c.
Rim weight is 3.85kg , not too unbelievable cheap.
And trust between buyer and seller.
Reactions: minibeany
That's insanely light for a 15". Good stuff bro
The spec on paper for 15' is not that light. It's around 9.3-9.7lbs or 4.2-4.4kg. Still very light nonetheless. The 15' which is under 4kg as far as I know is only Racing Hart CP035 at about 3.9kg.
The return of the Lotus name to Formula 1 racing had many race fans applaud the return of a brand that was as closely related to the series than some of the biggest names around today. The 1 Malaysia Racing Team acquired the rights to use the name from Proton and last week team principal Tony Fernandes announced that his group had acquired to use the 'Team Lotus' brand after acquiring it from its supposed...
