stupidcar
5,000 RPM
Why would you want that? U cant see leaks. Accessibility harder alsoAny sifu know is there anywhere selling those wira bottom engine cover? Like thise conti car have at their bottom of car one.
After changing my cam & crank sensor the 2nd time this year. I was thinking is it because my working area those stone,sand,mud thing cause this.Why would you want that? U cant see leaks. Accessibility harder also
Was the sensor that dirty?After changing my cam & crank sensor the 2nd time this year. I was thinking is it because my working area those stone,sand,mud thing cause this.
If yes,if I install this will it extend the life span of my cam & crank sensor and other part.
Juz my thinking only lah
Abit dirty at the sensor side bottom. Although After cleaning still cannot use la~Was the sensor that dirty?
If you see closely the pic,they have a vent in & out.If you close the bottom, where's all the heat that the engine produces going to?
Should not be an issue. My old pajero comes with a metal sump guard.If you close the bottom, where's all the heat that the engine produces going to?
Is your wira lowered ?After changing my cam & crank sensor the 2nd time this year. I was thinking is it because my working area those stone,sand,mud thing cause this.
what crank adjustment? haha. buy complete with wiring, ac and power steering system. easy to swap if complete.Actually my friend wanna sell his 4g92 sohc engine.
But juz engine only abit susah.
And also the crank need to adjust something.
Like bro. Izso mentioned something might be shorting the sensor........Wira update.
After changing both cam & crank sensor the car start nicely and didn't mati agn until...... Today.....
Lucky the car can start back without taking the battery wire off. Juz turn the key few time and it start back agn.
After makan breakfast I went back to the workshop,the boss see my car also kepala pening. He unplug all the wire on the ecu and wait for his checking result....
The mechanic had check all my sensor. Everything is running fine.Like bro. Izso mentioned something might be shorting the sensor........
Check your wiring for the sensors leading back to the ecu. If it aint the wiring, it has to be the ecu. Sensors relay information back to the ecu. It's the ecu that makes the decisions.The mechanic had check all my sensor. Everything is running fine.
Today morning it juz suddenly went dead agn. Starting to getting piss by the vdo thingy. Although is nice to use but when it got problem is really haed to know which thing break down. Diagnose also didn't come out any code is quite difficult.
