KHNG940413
668
56
johor bahru
Why would you want that? U cant see leaks. Accessibility harder also
After changing my cam & crank sensor the 2nd time this year. I was thinking is it because my working area those stone,sand,mud thing cause this.
If yes,if I install this will it extend the life span of my cam & crank sensor and other part.
Juz my thinking only lah
parakey
1,367
226
Was the sensor that dirty?
alcyon
800
153
543
Is your wira lowered ?
KHNG940413
668
56
johor bahru
Wira update.
After changing both cam & crank sensor the car start nicely and didn't mati agn until...... Today.....
Lucky the car can start back without taking the battery wire off. Juz turn the key few time and it start back agn.
After makan breakfast I went back to the workshop,the boss see my car also kepala pening. He unplug all the wire on the ecu and wait for his checking result....
Wira update.
Like bro. Izso mentioned something might be shorting the sensor........
KHNG940413
668
56
johor bahru
The mechanic had check all my sensor. Everything is running fine.
Today morning it juz suddenly went dead agn. Starting to getting piss by the vdo thingy. Although is nice to use but when it got problem is really haed to know which thing break down. Diagnose also didn't come out any code is quite difficult.
parakey
1,367
226
Check your wiring for the sensors leading back to the ecu. If it aint the wiring, it has to be the ecu. Sensors relay information back to the ecu. It's the ecu that makes the decisions.
guys, my carby engine have a irritating problem...the engine timing drops which causes the car to jerk when enter cornering especially if you tekan minyak in corners...its like a feeling of lack of petrol lidat...btw, my car is LE EE80........
