Things are like that mah~ gv & take one~Some times I think carburetor car is better, for longetivity that is....my old proton saga never gave these kinds of problems, sure the idling wasnt the most consistent, but it will always run.
Hahahahaha
2 cranks sensors in the space of a year? What happened to the first one?Last Tuesday I had the 2nd one after I own thus car.
Hahahahahaha
i'm still trying to understand this.. read below for the main sensors in 4G15 VDOWira update
My car while driving the engine suddenly went dead. Usually i thought is throttle body kotor something like that.
But this time is a bit different. The car engine went dead and cannot start. After checking thr 1st time is the camshaft sensor. After checking it the engine is went well.
The 3rd day the engine went deed again in front if mamakbstire. And cannot start agn. I call my technician he told me to took the negative wire out for 5 minute then tie back. After doing it the engine can start again.
Today,lagi syok. The car engine terus went dead in the middle of the road. After doing the some thing as yesterday the engine still cannot start. So I just tie back the wire and wait abit long time suddenly the car start up agn. I terus drive to the workshop asap.
Now what I know is the car wiring or sensor thing got issue but didn't kNow what went wrong. Quite piss off. Hahahahahaha
The 1st one rosak already. When my car 1st time engine dead & plug the obd2 port we saw the crank sensor issue. After replacing it everything went fine.2 cranks sensors in the space of a year? What happened to the first one?
Copied from LYN thread here
SENSOR LIST* (for 4G13/15 engines with Siemens-VDO EMS)
1] Intake Air Temperature Sensor: similar to Manifold Temperature Sensor but mounted with a clip on the intake ram pipe after the air filter housing.
2] Throttle Position Sensor: located inside the "blackbox" on the throttle body, which is the the housing for the TPS and servo motor.
3] Manifold Absolute Pressure Sensor: mounted on top of the intake manifold directly (no vacuum hose) with two 8mm bolts.
4] Coolant Sensor: mounted near the termostat of the cooling system. Screw-in type.
5] Oxygen Sensor: mounted on the exhaust manifold, before the catalytic converter. Screw-in type.
6] Crankshaft Position Sensor: 2-part - timing rotor welded on the crank pulley, hall-effect sensor mounted on a bracket with a 8mm bolt, beside the pulley, below the alternator.
7] Camshaft position Sensor: (possibly) located inside the ignition distributor.
8] Crank Pressure Sensing Switch: mounted on the engine block, behind the exhaust manifold. Screw-in type.
9] Fuel Pressure Regulator**: non-electronic "vacuum sensing switch" to control the fuel pressure mechanically. Located at the end of the fuel rail, mounted with two 10mm bolts.
source: http://drexchan.fotopic.net/c1099737.html
Everything manual.....lolSome times I think carburetor car is better, for longetivity that is....my old proton saga never gave these kinds of problems, sure the idling wasnt the most consistent, but it will always run.
You should find out what happened to the second sensor to cause it to die. Sounds like short or physical damage if you ask me. If it's a short then GG..... if it's physical damage you going off-road a lot ah?The 1st one rosak already. When my car 1st time engine dead & plug the obd2 port we saw the crank sensor issue. After replacing it everything went fine.
After 2 day then the car went dead agn.
Believe me MMC has it's own set of problems. MMC is also more "dumber" so needs a lot more input from you to make it work. Then there's the dreaded throttle body screw....... hahahahamy friend start to persuade me to switch to a mmc.
Lmaoooo
swap to MMC 4G92 DOHC. hahahahaFor me I had
For me I had chg
Air flow
Can sensor
Crank sensor x2
Oxygen sensor
The nightmare has come to me. Hahahahhaaha
What I afraid the most is those wiring & sensor thingy rosakI really don't have a clue to fix it.
MMC more powwah. #iHeartMMCBelieve me MMC has it's own set of problems. MMC is also more "dumber" so needs a lot more input from you to make it work. Then there's the dreaded throttle body screw....... hahahaha
Tbh, I dont see how VDO is smarter when all it's sensors left, right and center breaks down so oftenBelieve me MMC has it's own set of problems. MMC is also more "dumber" so needs a lot more input from you to make it work. Then there's the dreaded throttle body screw....... hahahaha
Actually my friend wanna sell his 4g92 sohc engine.swap to MMC 4G92 DOHC. hahahaha
Very2 long time ago when my hair are all still black, there is one company whom makes and sell this.Its a local brand. However i dont recall the name brand or if they are still around. Maybe other member with more white hair than me can shed sone light.Any sifu know is there anywhere selling those wira bottom engine cover? Like thise conti car have at their bottom of car one.
