4g13 talks
Valve seats sorry. Basically incomplete combustion busting out.
Personally I'd fix it. This kinda thing usually means overhaul. Piston rings and valve seats
I thought valve seats usually smokes when idling. One of my previous car had that, but normal driving no smoke, only at idling.....
parakey
1,367
226
During high vacuum situations like idle, cold start and engine braking, engine oil gets suck from the cylinder head into the combustion chamber.
lsm1991
1,469
185
Btw guys.. is it worth if i were to change my injector to higher cc on stock engine?
what do you think will happen... keep things simple. imagine just dumping more fuel in there, whats the expected result... remember just dumping fuel and nothing else into the combustion chamber
larger injectors won't shoot more fuel in la. It's just underutilizing the injectors. Not a great thing either
ehh it will let more fuel in kan...
Let me clarify. The stock injector duty cycle is usually 80%. So say you're using 150cc stock injectors, then you're shooting about 80% in super simple terms.
If you plonk in 500cc injectors it'll be running the default duty cycle of 80% unless you tune it otherwise. So you're shooting 80% of the 500cc inejectors. But that's also assuming your fuel pump can cope with the extra load. If fuel pump is insufficient and injectors not running at it's preset duty cycle, I think something is going to fail pretty quickly.
Latebloomer
89
4
27
So thats mean Ecu come first then larger injector plonk later on?
'(00): No man should ever see the pathetic sight of his Supercar, injured by the sidewalk. Even less a barely-year-old LP570-4 Superleggera (The Latest GSL mind you) Reasons for cause aside, this wrecked exotic was seen half on and off the curb with it's passenger-side front substantially defaced and also missing a front wheel...
