For the moment, just use plain water. Flush it every few days or weekends, until you are satisfied it's clean
Yup, I did it this way when first time flush, because after running the engine still got rust from engine block, so flush weekly for 3 to 4 weeks then only add coolant......lol
KHNG940413
668
56
johor bahru
Cant stoke a fire unless the tinder was already glowing. :driver:
Be careful with some items. Some may be of poor quality
Will always see the review before doing any purchase. Abit more safer. For now all the thing I bought is ok juz 1 time a bottle spill out the seller resend a new one to me.
minibeany
598
102
543
Will do it this time... 2x flush before add coolant. And make sure I drive a bit more during that 3 to 4 weeks :-). Now, CMCA and WFH.... no where to go... want to go eat roti canai also cannot.
sanekit
Dec 9, 2015
1,616
157
add full coolant first. let the rust all tanggal and floating. then take out coolant and flush with running water. add again coolant and let it run again. repeat with running water. LOL
KHNG940413
668
56
johor bahru
Wira update.
Got some tyre fender & a pair of universal fog lights for the car.
Didn't know the size but actually is the same size. Lucky me.hahahahahhaa
My colleague had hlp me to do the wiring for it sincr I am kinda stupid at that part.
After that I had chg the tyre fender. What I found out is the fitment doesn't fit well. Although the hole is same as the ori one but still lari abit.
But..... Nothing cannot use cablebtie to settle lah.
Those hole lari one I had use cable tie to tie up to prevent the fender went loose.
Juz a little pain in the axx if I want open the bumper.(need to cut of all the cable tie,hahahahahhaha
My car is a 1.5 vdo but it came with 1.6/1.8 radiator & condenser(all are stock I guess
The ex owner chg it and works fine so I didn't bother it.hahahahahaha
actually - that looks like the Wira SE automatic rad. The automatic is full sized left to right, manual is half the size. I don't know about the 1.3 one though
sanekit
Dec 9, 2015
1,616
157
1.3 is manual use half size rad with half size condenser next to it. auto wira uses the long radiator with long condenser in front.
KHNG940413
668
56
johor bahru
Wira update.
Cannot tahan the seat. Feels like sitting on a sheet of kain. So went to tambah some sponge and now feel a bit more spongy & abit higher.
I was consider to get those replica recaro seat that can support my leg since my leg is a bit long. Driving long distance my leg cannot stretch quite uncomfortable.
hi does rr engine fit honda city 2009 body???
---------- Post added at 01:25 AM ---------- 6 hour anti-bump limit - Previous post was at 01:24 AM ----------
i wan some power in my car but i dunno wat should i do , can give any advice , sum1 tell me rr fit but sum say dun fit , sumore rr engine expensive, any cheaper way??
