Knocking sound from engine
i think u better get the regulator first.. im not sure stock kenari fuel pump is enuf to support, but at least u can crank up the regulator pressure and achieve safe pressure for ur turbo engine.. then can get suitable fuel pump to install.
If his original got no return means pressure already controlled by ECU? If yes, will the regulator work?
Guys, i hav a knocking issue.
My waja (renault) engine havent being driven since last Dec and i only drive it around the neighbourhood once or twice a month and start the engine every weekend.
Last week, i notices the engine knock whenever i do moderate acceleration be it flat ground or slight climb. This does not happen before last Dec.
I can only think of 2 things...
-engine require tune up. Unlikely as i never remove the battery terminal. Then again, this cas is quite sensitive to low battery and it happen at least twice where the starter only turns once and car could start before i hook on the charger.
-timing belt problem as i encounter before a melted either tensioner or idler pulley when i forgot that the timing belt interval is 60k and its already 80k. this timing belt has another 20k of life on it.
Done 60k km, but how long ago when changed?
My Accord last time, bought 2nd hand done 30+k km. Mechanic say can change at 60k, so continue using. At 40+k km timing belt broke but already passed 5 years. Therefore to me is like engine oil, 10k km or 6 months, so timing belt, for me is recommended mileage vs 5 years.......lol
OH! what fuel you using? Hope is not Shell 95, my VR totally cannot run on it.......lol
Nope i havent used shell for years. Bad fc and that feeling of engine not running smooth. Caltex/BHP most of the time. When both not available it will be Petronas.
On the timing belt...i totally dont recall.as short as 3 years to as long as 5 years.
Timing belt cost...ouch....Guess it will rest a bit longer.
u can try fuel-up with caltex ron97 full tank and drive it a little bit hard to cleanup carbon deposits inside the engine...
Go highway cruise at 110kph also can, my wife always say engine smooth and better to drive after coming back from outstation.......lol
Reactions: ^pomen_GTR^
Thank you guys.
I'll try Caltex 97 first when i decided to drive it.
Update,
after making the car legal again last month i pour in Petron first as thats the nearest brand available that time. Knocking is still there.
Once empty, pour in Caltex 95 and it reduces the knocking after 1/2 tank. Now its gone. Should have use my endoscope to see inside the cylinder for before and after.
On a side note, anybody notice the kinda-nice smell the exhaust produce when using caltex?
I notice this on both my BLM and Waja.
Update,
Makes no difference for my cheapass Myvi. Smells equally bad
My VR have issues with Shell. Long ago tried before, lost power. Last year tried again, after 2nd tank drop in power, 3rd tank won't rev past 4k RPM. Now back to Petron running fine......lol
Hello, does anyone have information about changing geran?
Yesterday I went to post office to renew my roadtax, but because of the roadtax renewal space was full (at the back of the geran letter) so the post office guy said I cant renew it in post office, I have to go to jpj to change to new geran letter, my question is what is the process of changing the geran? What should I prepare and how much it will cost me? Does anyone experienced this before?
Really appreciate your help,
Thanks...
