knocking sound like "dak dak dak" occur
niccm0314
May 20, 2012
13
503
negeri sembilan
Hi,
This is my 4g13p, i hear some knocking sound like "dak dak dak" occur, isn't that is coming from the valve clearance problem?
i had adjusted my valve clearance in hot engine with the Inlet valves - ------0.20mm (0.008 in)
Exhaust valves-----0.25mm (0.10 in). please advice me thanks..
Here is my youtube link for my engine..
4g13p knocking sound from valve clearance problem? - YouTube
Beside this may i know play with the marking of cam? The picture that i inserted show the valve clearance that adjusted with the cam in the marking mark, need to adjust the red circle valve.The problem is when i need to adjust the valve marked arrow in the picture, how do i need to turn the crank n make it accurate from the cam in marking turn 180 clock wise?
Anybody tried buying china oxygen sensor before? Anyone bought before and is it ok?
I tried to find new oxygen sensor for my car, its a nissan primera P12 engine. The sensor connector is light blue color, with 3 wires. Couldnt find original or branded oem sensor. All i can find is china brand or no brand oxygen sensor from china..
