Lancer CVT with Supercharger
Partially agree, aftermarket kit usually requires modification as well, unleass the kit is really made for the car type, hence the price of it will be super expensive and not ideal. Since custom supercharging kit is much easier compare to turbocharge, by right it would be cheaper, but finding the people who know to fabricate the job is also another challenge. In my case, there is no readily made supercharging kit made for Lancer, even from the article i shared, its also custom built kit.
Besides going Rotrex, some Aussie folks suggested Eaton which is a twin screw type. The aim of this supercharging discussion is to minimize the sudden burst of power while increase torque across all rpm range. I welcome any ideas exchange.
Where is the fun of it if it is too easy :burnout:?
Thanks,
Ken
to me... the best supercharger unit still will be the root type/twin screw type...
compared to the turbine type supercharger is just exactly a turbocharger unit cut in half and slapped with pulley and high ratio gearing...
means at low rpm it doesnt get up much....
with root/twin screw type...u get instant powahhh :wheelspin:
Approximate 9k, but still have custom the mount as well, so a little over 9k.
9k just for the Sc without intercooler, piping, pulley and other accessories kit? I thought 9k is already including some basic kit like the pulley and intercooler, no?
But root/twin screw type lack at higher rpm, right? Plus they take up a lot more space for installation too.
For turbine type, depends on the pulley ratio too I think, but yeah the response is still more linear/smoother power curve, unlike root/twin screw or turbocharger.
Mitevo7
1,456
179
9k for whole kit, without intercooler, but recommend to get one to prevent heat issue. Pulley will be chstom when order.
Mitevo7
1,456
179
Might not be good idea, this CVT hates anything that provides too much sudden boost.
Thats why Rotrex centrifugal type by far is the best match fot compact engine bay. Even car like jazz can fit it in nice and clean.
sweelt
Nov 6, 2016
2,306
248
visit levelten, just now. Glimpse through torque converter. Interesting.
Same principle as factory motor - belt driven gearbox. We called it hydraulic coupling. Safety plug will burst if overload.
Duno how it work for car. Got safety plug ? hehehe :hmmmm:
nope... twin screw/root sc will give linear boost.... boos usually stays really flat...
turbine/centrifugal type sc will increase boost exponentially (depend on blade design and size) as rpm increase...which is definately not linear...
or i would say like a laggy turbo that needs rpm for boost....
root/twinscrew is the linear boost....
Mitevo7
1,456
179
But it looks like too much power at low rpm, especially if you in D drive and stuck in jamme, holding the brakes. Well i am not sure whether they have the release clutch tech like those in dual clutch.
Thanks,
Ken
Thanks,
Ken
Got Low end torque only nice to drive mah.....lol
Thanks,
Ken
when in D u can crawl in traffic without touching the throttle....
boost only came on when u open up the throttle....
plus cvt usually have the torque converter or clutch mechanism as well...
so in idle no boost...and the cvt stress should be pretty much like stock car in D as well...
Mitevo7
1,456
179
Poison again ???
That sounds pretty good, Lancer GT's is torque converter type CVT though.
Mitevo7
1,456
179
Preparing For Your Car Radiator Flush
Your car's radiator and cooling system needs to be clean to be cool. As time goes on, your car's radiator builds solid deposits that can clog the cooling system. A quick, inexpensive radiator flush can keep the system in shape. It's important to change your antifreeze seasonally.
Before you start your radiator flush, make sure you have...
