4g63 Turbo Setup
so the dark side has summoned you? :adore:
stock injector, just look at the color. Yellow if I not wrong, 450cc.
most of the evo owners will go for Haltech or micotec, emanage at this level, is redundant.
Reason, probably the map setting and flexibility?
Whatever you took out sell to bro Marshal just nice......lol:biggrin:
marsha1l_v6
666
130
543
i think you already installed those macam macam bars, UR ...etc. ?
Only front mount (top /bottom) rear mount (bottom) and UR ring and adjustable, one that improve handling from stock. Thinking of foaming the frame, but if to rigid, then impact wont be absorb much if i hit anything :confused::smokin:
Stock EVO 3 injectors are yellow in color and it is 510cc and you don't have to upgrade the injectors to hit 300whp. (If want to upgrade, you can consider the later EVO injectors at 560cc (EVO V onwards). Secondly, minimum an Emanage-Blue is needed and definitely an Electronic Boost Controller. The rest in your upgrade list is about right
thanks bro, ill check the injectors. hopefully with 510cc/560cc the duty cycle is below 80%, no experience on this. Else, can just go for 650cc then.
what is a digital cluster meter?
any picture to share?
something like this . New cost 2.1kish
https://www.google.com/search?q=haltech+digital+display&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjGraDSw8rRAhUGsJQKHTG_A5UQ_AUICCgB&biw=1661&bih=587#imgrc=TW8FgmL3L7AEqM%3A
https://brewedmotors.com/image/cache/data/Brews/brewed-digital-dash-display-600x800.jpg
:driver::love:
kurt_629
872
54
johor
:driver::love:
wah.. envy.. :love:
the haltech digital display is damn stylo
it definitely feel good to be rich..
not for the poor
peterj
1,321
258
1,683
Kuching
Gt g4 link evo pnp as now the price much more cheaper dy
marsha1l_v6
666
130
543
thats a piggyback right?
PC of a pc which is known as computer or pc - personal car.....hehehe
personal computer..hahaha..its a stage by stage upgrade...not one shot..this coming weekend exhaust,then able to boost abit, ppl say angin lawas but under 1bar due to v6 fuel pump, then fuel pump/regulator..this time will go for 1bar..and see if there is any need handling/braking improvement..at this point, if got extra cash, ill go haltech + 650cc injector(expensive aftermarket injector) +ebc...else just emanage and be content with what i have..hahahaha
Engine damper, does it work? I mean can it reduce the chances of my mounting koyak?:burnout:
peterj
1,321
258
1,683
Kuching
Nope, links g4 evo plug in is standalone ecu by links which direct plug in to your old ecu casing, plug all oem wiring back and mostly done except the hose for map sensor(maf to map conversion and also intake air temp input).. And there are much more function to play with as well.. If want more cheaper option, opt for power fc which ppl done for e123, saw one that day fast sold at 1.7k only, power fc job also pnp with much more simple procedure as compared to linls g4 evo plug in:driver::listen:
sweelt
Nov 6, 2016
2,306
248
i put radiator for my processor.....:rofl:
i worry body koyak, rubber mounting can change.
where can tambat, tambat lah....hehehe
marsha1l_v6
666
130
543
looks promising, my bad, not familiar with aftermarket ecu. will look into this.
nice,so do i full system with radiator. Yea what i meant was the body/chassis especially at mounting point regioin.:smokin:
kurt_629
872
54
johor
try not always floored 1st and 2nd gear....i do that, once a while can lah.
any particular reason?
my friend taught me how to drive a turbo recently, activate when at gear 3, then full boost, shift to 4 and repeat till 5.
i need to know what glue to use to stick those black color rubber thingy at the door of ur car..
i tried with dunlop glue but it seems to melt in hot sun...
