I have done checking the alternator i think its still.okay,it still running,maybe wiring but dont know what wire cause it to happenAlternator not charging?
Not yet,can i check using multimeter?Did you check with amp meter the charging rate?
Value of amp and volt how much to see its still okay
Are u sure not the wiring stuff? Because it happen after i change the starter
I have done unplug the negative panel while engine is running,engine still running like usual,but the two indicator light on and off,its like blink blink,until the alarm came out,(i think it tell because of no battery coz i unplug the negative panel)Anyway, just test to make sure it is not the alternator problem then you can start looking elsewhere once you rule out the alternator.
If you have just change the starter, the wiring is quite direct. Remove starter fit back and wiring is receiving power from battery.
Maybe you can check your car manual what else the battery light on is for. In my car when that light is on, means no charge....
vr2turbo - only you can look at a generic picture and troubleshoot a problem
18quattro48 - Bro, what are you complaining about? I don't understand the picture. High idling rev? Or battery warning light? Which is the problem you're talking about?
The handbrake and battery indicator light on at the same time,when i drive the car,it will blink2,but when this two indicator is turn off,my head light turn a bit dim,when this two indicator light on,the head light became brightvr2turbo - only you can look at a generic picture and troubleshoot a problem [emoji3]
Perodua kenari just a standard car,with the old stuff in itSometimes when the handbrake light is blinking, it might be an indicator of ABS failure. What car is this? Does it have ABS? If yes did you check ABS sensors and wiring?
As for battery light and the dimming - there's a few possibilities to check. How old is your car? If old perhaps it's just poor stock grounding. Is your car modified? Accident before? Might be worth doing an aftermarket grounding kit.
Alternator if about to die might seem to work for a while and intermittently fail. Worth checking out too.
