What cause it to happen?
30,002
Value of amp and volt how much to see its still okay
How many amps depends on the size of your alternator, usually 90amps or more.
New car battery is 2.1v per cell so should read 12.6v
Voltage to be able to charged up your battery should be 13.5 to 14.8v
30,002
Are u sure not the wiring stuff? Because it happen after i change the starter
Anyway, just test to make sure it is not the alternator problem then you can start looking elsewhere once you rule out the alternator.
If you have just change the starter, the wiring is quite direct. Remove starter fit back and wiring is receiving power from battery.
Maybe you can check your car manual what else the battery light on is for. In my car when that light is on, means no charge....
18quattro48
16
28
Ipoh Peraj
I have done unplug the negative panel while engine is running,engine still running like usual,but the two indicator light on and off,its like blink blink,until the alarm came out,(i think it tell because of no battery coz i unplug the negative panel)
15,390
vr2turbo - only you can look at a generic picture and troubleshoot a problem :biggrin:
18quattro48 - Bro, what are you complaining about? I don't understand the picture. High idling rev? Or battery warning light? Which is the problem you're talking about?
30,002
First thing I ask is alternator mah!......hhahahhaha
Engine running, battery charge light on, so I go that direction. He mentioned take out negative terminal engine still running. If alternator completely konk engine should die off. Since his still running ask him check the charge next.
You remember I went help Andrew one time his car stop at Federal Highway, I went there jump start for him, still run, then he went to my mechanic check the alternator weak not completely dead that is why he still can run until mechanic there
18quattro48
16
28
Ipoh Peraj
vr2turbo - only you can look at a generic picture and troubleshoot a problem [emoji3]
The handbrake and battery indicator light on at the same time,when i drive the car,it will blink2,but when this two indicator is turn off,my head light turn a bit dim,when this two indicator light on,the head light became bright
15,390
Sometimes when the handbrake light is blinking, it might be an indicator of ABS failure. What car is this? Does it have ABS? If yes did you check ABS sensors and wiring?
As for battery light and the dimming - there's a few possibilities to check. How old is your car? If old perhaps it's just poor stock grounding. Is your car modified? Accident before? Might be worth doing an aftermarket grounding kit.
Alternator if about to die might seem to work for a while and intermittently fail. Worth checking out too.
18quattro48
16
28
Ipoh Peraj
Perodua kenari just a standard car,with the old stuff in it
30,002
Handbrake indicator light on also can mean low brake fluid level, but looks more like wiring since now it affects your head light too. Might need to send to wire man for checking....:hmmmm:
ken yeang
6,618
1,327
Only sifu like vr2turbo can troubleshoot, based on 90degree rotated picture.:biggrin:
