Need advise about my mirage turbo setup..
kambeng758x
Jul 20, 2015
11
41
Kulim kedah
could i bring up this thread.:proud:..long time not sembang about mirage..i have wira with mirage turbo enjin,but already change the block to vr4 from bottom to top..right now only wiring,trotel,ecu,air flow,turbo td04 mirage ( td04 11b i think ), gearbox only wira 1.6 huhu..then only upgrade the injector from vr4...could anybody suggest the best way for me to upgrade from those condition..some say just upgarade the ecu & air flow vr4..and some say upgrade the turbo to td05 ( any td05 evo1,2,3,vr4rs or td05 18g )...hope got respon from all sifus:adore::adore::adore::adore::adore::adore::adore::adore:
Mine is standard VR4, not RS but already have TD05, or halfcut owner in Japan already changed?:hmmmm:
You can also boost higher for better power but many things to do....:driver:
kambeng758x
Jul 20, 2015
11
41
Kulim kedah
Ooo..vr4 already?hihihi..very different from me lah..hihi..me only mirage 61t lah...just vr4 wannabe..boosting sometimes up to 1.0 bar only using tulang ikan..could u suggest any idea?right now im wonder rather i change the turbo 1st or chage the ecu and air flow to vr4?
U also the expert la..huhuhu..just wonder either to change the turbo or ecu and airflow
Not expert. Mine as mentioned standard only no further mod.
But for your mod, installing bigger turbo need to re-tune and/or add injector or change bigger injector as you cannot allow it to run too lean. Probably ECU re-tune also, or re-chip etc to add fuel. That is why I mentioned need expert....:smokin::driver:
kambeng758x
Jul 20, 2015
11
41
Kulim kedah
Everyday u on9 lah vr2turbo..me so happy lah.at least,somebody reply to my post.i know and feel u are also expert lah..looking at ur name also know lah..hihi...actually i think wanna go for turbo 1st..td05 better no need big modified. At least plug and play to my mirage manifold.. For Garret also best,but i think need extra modi..fuhhh so hard lah play turbo...aiyoo
Of course direct fit always better, no need mod it in. You mentioned change ECU, what about your wiring harness? Now is Mirage wiring?, will it run VR4 ECU?
kambeng758x
Jul 20, 2015
11
41
Kulim kedah
If you read previous post from otai2,they said ecu and air flow from vr4 just plug and play..all the socket same lah kot..just the electronic components inside la the different..kick me if im wrong..hihi:adore::adore:..so x tahan lah always kena tapau with GSR turbo..haiyo..
That not sure, but can you try before buying? If not, buy already don't work well then how?:smokin:
kambeng758x
Jul 20, 2015
11
41
Kulim kedah
Wahh..me already scare lah..luckily not buy yet..if not match ,then rugilah..to sell back take time lah..aiyooo..i think better try ecu and air flow from friend 1st..very good input from you la vr2turbo..
Hello folks! Has anybody tried to paint your own car before? Well, paintwork customizing will also count. I intend to give it a shot as well. Not to brag but I can draw so-so, hopefully it will turn out to be okay.
