i'm not kind off agresive driver vr2I presume you have been driving at 110kmh for 4 years, or over 120kmh.......
Vibration at 120kmh, so at 110kmh just nice, cruising with no vibration.....i'm not kind off agresive driver vr2
Myvi original is 175/65R14 so 185/55R15 is closer to your original diameter. 195/50R15 is slightly smaller.Hi all. I'm planning to change my stock 14" rims to 15". I roughly know the design of the rims I want (but not sure which brands are available for this specific design) but I'm unsure about tires I should use. Maybe either 185/55R15 or 195/50R15. And hence, the creation of this post. Mind giving some opinions on which one (and the brand as well) should I go for a comfort quiet ride?
Thanks in advance.
I know only that Hin Leong is open. You can take your pick and call them to check....Thanks for the info.
Another question; do the shops in Klang open on Sundays?
Hey, where did you get this set of wheels?I ended up with Advan Racing 15" and Michelin PS3 195/50/R15.
However, when I got out to the highway I felt vibration when I'm driving about 110km/h which did not happen before changing the rims and tires. This is mostly due to the balancing right?
Alright. Thanks for the info.I know only that Hin Leong is open. You can take your pick and call them to check....
Klang tyre shops.....
Ban Hooi Tayar Sdn Bhd
2057-2061, Batu 1, Jalan Kapar, Klang
41400 Selangor, Malaysia
Tel: 03-3342 3146
Eng Cheep Tyres
Batu 11, Jalan Kapar
Kapar, Klang
Selangor
Owner Mr Ti
HP: +60192142718
Jooi Seng Car Care Services Sdn Bhd
198, Lorong Sentosa 45, Off Jalan Batu Belah,
41050 Klang, Selangor
Tel: 03-3348 7499
Pusat Perkhidmatan Tayar Hock Li
132, Jalan Kapar, Klang
Tel: 03-3348 8539
Perkhidmatan Tayar Chin Heng Sdn Bhd
508, Batu 2 1/2, Jalan Kapar, Klang
Tel: 03-3341 2633
Hin Leong Tyre Services
134 & 136, Jalan Kapar
41400 Klang, Selangor
Tel: 03-3343 9100
use achilless atr sport 195/55/15 around below rm200 each...or yokohama parada 195/50/15..the price in the same range....kl rate....Planning to upsize mine to 15" and was thinking of 195/55/R15 as well. With a budget of say plus minus RM200 (maximum around RM220) per piece, what are some options I have? Any list of tires from RM200 below all the way up to the maximum I'm willing to fork out at RM220 per piece?
Also, while 195/55/R15 seems to be good, why are many shops recommending 195/50/R15 instead?
Your opinions are very much appreciated.
8JJ to wide for 195 size tyres. 6 to 6.5J is enough.15 inch 8jj offset 20,myvi1.5 not lowered, tyre 195/55/15 will this type of set up can fit into myvi nicely? any problem with that?
cause recently i found a 15 inch rim on mudah, rota grid TE37 acutally, it's look really nice... but offset and rim are too wide but seriously the spoke curve in damn nice!... any other rim got almost the same design? as im look those 15 inch rim spoke that curve from the hub out to the end of the lip... any suggestion?8JJ to wide for 195 size tyres. 6 to 6.5J is enough.
Again offset 20 is too far out. Myvi, if not mistaken use offset 40 just nice
Can't help you with rim design. You have to see it to love it. However for Myvi you have to keep the offset at around 40 or slightly more.cause recently i found a 15 inch rim on mudah, rota grid TE37 acutally, it's look really nice... but offset and rim are too wide but seriously the spoke curve in damn nice!... any other rim got almost the same design? as im look those 15 inch rim spoke that curve from the hub out to the end of the lip... any suggestion?
if offset 35 cannot? why? :hmmmm: cause i saw few myvi with bbs rim offset 35.. so if we put offset 35 what will happen?Can't help you with rim design. You have to see it to love it. However for Myvi you have to keep the offset at around 40 or slightly more.
Offset 35 will look better with wheels coming out more. Problems faced will be tyre scrubbing the rear wheel outer fender, if use 195/55R15 when carrying heavy load.if offset 35 cannot? why? :hmmmm: cause i saw few myvi with bbs rim offset 35.. so if we put offset 35 what will happen?
