wut is the best tyre size for myvi??
heryky
May 3, 2012
29
Hi all. I'm planning to change my stock 14" rims to 15". I roughly know the design of the rims I want (but not sure which brands are available for this specific design) but I'm unsure about tires I should use. Maybe either 185/55R15 or 195/50R15. And hence, the creation of this post. Mind giving some opinions on which one (and the brand as well) should I go for a comfort quiet ride?
Thanks in advance. :biggrin:
Myvi original is 175/65R14 so 185/55R15 is closer to your original diameter. 195/50R15 is slightly smaller.
Since you mention comfort quiet ride, 185/55R15 will have more comfort with 55 aspect ratio sidewall.
However if performance then 195/50R15 will be better. Wider pattern for more traction, 50 series for better handling.
Some prices as follows:
185/55R15
Michelin PS3 - RM250 Hup Shun SS3 (incl. valves & balancing) (Jan 12)
Michelin PS3 - RM229 Modern Tyres, Seremban Jaya (Dec 11)
Michelin PS3 - RM230 Ban Hooi,Klang (Mar 12)
Silverstone Synergy M5 - RM210 Tek Ming Auto Bdr Sunway (Nov 11)
195/50R15
Bridgestone Potenza RE002 - RM290 Hin Leong (Feb 12)
Bridgestone MY01 - RM175 Hin Leong (Dec 11)
ContinentalComfortContact5 - RM235 Mechanikar (Jan 12)
Falken ZE-912 - RM145 Hin Leong (Jan 12)
Goodyear F1 Directional 5 - RM260 Quicksave USJ (Sep 11)
Goodyear F1 Directional 5 - RM245 Ban Hooi (Dec 11)
Goodyear F1 Directional 5 - RM253 Hin Leong (Dec 11)
Goodyear Assurance - RM198 Hin Leong (Dec 11)
Michelin PS3 - RM250 Ban Hooi (Dec 11)
Michelin PS3 - RM238 Hin Leong (Feb 12)
Toyo T1R - RM260 Hin Leong (Dec 11)
Thanks for the info.
Another question; do the shops in Klang open on Sundays?
I know only that Hin Leong is open. You can take your pick and call them to check....
Klang tyre shops.....
Ban Hooi Tayar Sdn Bhd
2057-2061, Batu 1, Jalan Kapar, Klang
41400 Selangor, Malaysia
Tel: 03-3342 3146
Eng Cheep Tyres
Batu 11, Jalan Kapar
Kapar, Klang
Selangor
Owner Mr Ti
HP: +60192142718
Jooi Seng Car Care Services Sdn Bhd
198, Lorong Sentosa 45, Off Jalan Batu Belah,
41050 Klang, Selangor
Tel: 03-3348 7499
Pusat Perkhidmatan Tayar Hock Li
132, Jalan Kapar, Klang
Tel: 03-3348 8539
Perkhidmatan Tayar Chin Heng Sdn Bhd
508, Batu 2 1/2, Jalan Kapar, Klang
Tel: 03-3341 2633
Hin Leong Tyre Services
134 & 136, Jalan Kapar
41400 Klang, Selangor
Tel: 03-3343 9100
heryky
May 3, 2012
29
I ended up with Advan Racing 15" and Michelin PS3 195/50/R15.
However, when I got out to the highway I felt vibration when I'm driving about 110km/h which did not happen before changing the rims and tires. This is mostly due to the balancing right?
Hey, where did you get this set of wheels?
Tel: 03-3342 3146
Eng Cheep Tyres
Kapar, Klang
Selangor
Owner Mr Ti
HP: +60192142718
Tel: 03-3348 7499
Tel: 03-3348 8539
Tel: 03-3341 2633
Tel: 03-3343 9100
Alright. Thanks for the info. :biggrin:
spoon civic
403
36
528
terengganu
Planning to upsize mine to 15" and was thinking of 195/55/R15 as well. With a budget of say plus minus RM200 (maximum around RM220) per piece, what are some options I have? Any list of tires from RM200 below all the way up to the maximum I'm willing to fork out at RM220 per piece?
Also, while 195/55/R15 seems to be good, why are many shops recommending 195/50/R15 instead?
Your opinions are very much appreciated.
use achilless atr sport 195/55/15 around below rm200 each...or yokohama parada 195/50/15..the price in the same range....kl rate....
15 inch 8jj offset 20,myvi1.5 not lowered, tyre 195/55/15 will this type of set up can fit into myvi nicely? any problem with that?:adore:
8JJ to wide for 195 size tyres. 6 to 6.5J is enough.
Again offset 20 is too far out. Myvi, if not mistaken use offset 40 just nice
aranny2001
249
7
518
cause recently i found a 15 inch rim on mudah, rota grid TE37 acutally, it's look really nice... but offset and rim are too wide:bawling: but seriously the spoke curve in damn nice!:love:... any other rim got almost the same design? as im look those 15 inch rim spoke that curve from the hub out to the end of the lip... any suggestion? :adore:
Can't help you with rim design. You have to see it to love it. However for Myvi you have to keep the offset at around 40 or slightly more.
if offset 35 cannot? why? :hmmmm: cause i saw few myvi with bbs rim offset 35.. so if we put offset 35 what will happen?
Offset 35 will look better with wheels coming out more. Problems faced will be tyre scrubbing the rear wheel outer fender, if use 195/55R15 when carrying heavy load.
195/50R15 maybe okay.
You can try rolling the fender or using stiffer springs.....
OKLY
121
6
518
Selangor
Hi all, I am currently on 195/55/R15 (rim is 6.5jj width and 37mm offset, using Eibach Pro-Kit springs on stock absorbers which I get about 3 fingers gap for the rear. When there's no load behind then it is fine but if I carry just 1 person behind also I tend to hear some sort of sound from the rear when the road is uneven or very rough.
I know 195/55/R15 isn't exactly the ideal size but I like it for its balance of performance and comfort and also it fills up the fender area nicely.
What are the possible solutions for this apart from changing back to 195/50?
Alert!!! Tyres being slash/punctured in PJ!!!
For those staying in SS23 PJ and surrounding area please be aware that there are individuals or groups that is going around the area between 3-6a.m and punturing car tyres by stabbing the side walls of the tyres for the pass 1 week. Up to date there has been at least 20 cars in the neighbourhood that park their cars outside that has gotten one or two tyres damage by these people. As you cannot fixed punctures on the side wall the only...
