Removing Water Spots on rear Windscreen
Today was washing my VR, then decide to clear the water spots on the rear windscreen. The VR have been parked in the open 24/7 for a long time already and water spots have appeared on the rear windscreen. Have been there a while, only lazy to clear them until now....hahhaha:biggrin:
Water Spots/Marks on the glass. To remove by Polishing also will take a long time with rotary
When wet with water it becomes worse. Driving in the rain at night becomes very difficult
Don't mind the bottle as the glass acid was given by a friend. He mentioned getting it from Honda SC and that is the only bottle he could find, so I also do not know the actual brand except it is glass acid. Similar to this you can check out Tom Cat or Formahero water stain remover, but do not use these products on the front windscreen.
This acid just apply onto a cloth and scrub hard. Depending on how stubborn the water marks, you may need to scrub two to three rounds to remove the stains. Wear rubber gloves if not the acid will sting your hands.
Right side after scrub clean with glass acid. Water sheeting over the clean glass. For comparison left side full of water marks
Completed. Washed and dried. No more water marks.
Thanks for viewing......:wavey:
humongousgravy
189
Seremban
I went to do this at a workshop, and yes those watermarks were gone but with that came swirl marks that are visible when light shines and other scratches that is getting on my nerves. I am told there is no way to remove them except to change the windows, I hope that is not true?
Btw, how much does the acid cost normally?
If you have swirls means the shop did polishing by rotary using compound. This can create swirls.
I heard there is a special glass polish (cerium oxide) that can polish it back, but I think still will need a rotary polisher to do it.
Acid base is to dissolve the water spot and remove so no harm to the glass. Those Tomcat and Formahero should be around RM16 a bottle.
Supra_Fanatics
20,673
3,998
But how come only windscreen cant use ar bro? Cuz windscreen also ada watermarks haha!
Guess Rain X good enough though.
now i use AWOC...better than rainX....no wiper jumping2...no mist on outside if stuck in traffic..and works better...
i bring small bottle can get a bit?? :listen:
Blanc2z
May 24, 2013
23
503
Subang Jaya
I use Mosiac Cleaner from my local hardware store which I buy for like 10 bucks tops. used for cleaning toilets but works everytime! I have like half a bottle left... bought it around February last year. this stuff works wonders :biggrin:
g88
3,081
54
5,148
All these acid , mosaic cleaner does clean the watermark but same time killed the surface sheeting capability....which you need to compound or re-polish back...
Front windscreen can use but must be very very careful. Must wash off before it dries. Front windscreen when use wipers will have micro lines scratched into them and if these acid fluid seeps in and dries, it turn white then your windscreen vision will be blocked and it is a pain in the a** to remove. Even with rotary and compound also difficult to remove....:banghead:
---------- Post added at 02:58 PM ---------- 6 hour anti-bump limit - Previous post was at 02:57 PM ----------
Glass polish and rain X.....:driver:
Supra_Fanatics
20,673
3,998
AWOC where can get? Ace ?
g88
3,081
54
5,148
Supra_Fanatics
20,673
3,998
One comment on the video is same as Rain X only.....hhahahhahahhah:rofl:
Wah! If buy rain X and re-bottle / repack can make a lot woh!:smokin:
Good idea xD
Is anyone know where can i buy the arb bush? I already change my rear arb
to mivec arb, which diameter is 16 mm. Most of the spare part shop I went,
didn't has this part and I just bought one but cannot fit. Any advice from
you all. Thanks.
