Feedback needed
bbphire
9
503
that day i sent my car, Lexus LS 250 size 245/45/17 to sevice and only i realize that my tyre tread had completely wear off. omg, so dangerous!! the service advisor advice me to change my car tyre and he suggest me to get Michelin PS3. is this tyre really good? quite exp thou. anyone tried before? is it worth getting? cause if exp but good, then still ok geh..
cvkit17
2,884
1,354
How much? You should go to tyre price thread to compare the price. Although I have not used PS3 before, I have heard many good feedback.
Aiya.. Michelin PS3 you can't go wrong la. Just make sure you don't have bulging sidewalls or peeling tyre thread which seems to be the usual complaints for the PS3. But at the same time if you don't have issues the PS3 is a pretty good tyre.
Usually you won't go wrong with Michelin.
Yup, PS3 is proven. Many good feedback. But are you getting them from the SC. I think they will be more expensive. Probably you can check the prices with outside tyre shops.
Having said that you can browse through other brands like Yoko, GY, Conti and so on too to compare their prices. Yoko top is Advan V105, GY Asy2, Conti CSC5, Toyo T1-Sports to name a few...:driver:
es2611
951
175
if michelin could supply tires for airbus A380.. i think they would make a wonderful road going tires. enough said.
thunder77
Nov 9, 2013
20
503
Michelin always come out with the tyre which meet the latest technology, their advance technology make them one of the top tyre brand. The quality for Michelin ture is very good. It is also a chosen tyre for Leman contest. And the design of tyre is up to date and even Porche is using Michelin tyre.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Don't be such an obvious advertiser la.
RENESIS VIII
7,063
950
Ipoh
Because it is Michelin. Top brand mah!....:smokin:
---------- Post added at 09:50 PM ---------- 6 hour anti-bump limit - Previous post was at 09:46 PM ----------
Maybe is IS250....:driver:
Yeah maybe it could be IS. The only 250 I've heard before is IS, ES and GS only.
dkny
211
10
FYI
World Ranking 1= Bridgestone
No 2 = Michelin.
---------- Post added at 10:20 PM ---------- 6 hour anti-bump limit - Previous post was at 10:18 PM ----------
PS3 = Sport Tyre
For Lexus I will suggest Primacy 3 , or Bridgestone GR100, or Toyo C1S , if u want comfort + Quietness.
dip
Jul 1, 2014
14
34
why so concern about tyre? Tyre not all same ar? I never choose my tyre by myself,I always depends on service centre to recommend me tyre that suitable for my car..
Hi,
Can anyone recommend me a good car restoration shop that doesn't charge too much? I need to change my door hinge, weatherstrip on both side of the door and rear bonnet, some small rubber lining on the front windshield, solve annoying minor sound from the body( most likely coming from behind), and some sound proofing.
For weatherstrip i cant use those normal type like on wira etc, as the door shape has its on clippings etc.
