Best grip vs Price
pwhyze
924
356
1,563
[/COLOR]
Why nankang ns2r get the extreme level since the outcome from the user said that its not good at all from grip in wet nor dry. oso being the same level with ad08 seems to be exaggerating for that tyre.
now for the price federal vs toyo vs yoko vs hankook for semi slick n grip, which one the best bos?
Are you sure that review is for the NS2R or is it NS2? NS2R got decent rating as one of the cheapest extreme level tires around.
I dont think wet grip is as bad gua. :bawling:
Use until that time then can compare, but ATR may be better as got no sipes and bigger grooves. Compound traction AA, hope this is true rating then should be good....:driver:
---------- Post added at 09:04 PM ---------- 6 hour anti-bump limit - Previous post was at 09:02 PM ----------
[/COLOR]
What I posted in not my grouping. It is category by the tyre brand manufacturers on what model for what use. Whether which performs better depends....
KenDiriwan
1,283
225
kendiriwan.multiply.com
You will only be satisfied by T1R for the first 30-40%. I rather go for Ventus V12/PS3
xbalance2002
1,501
349
1,683
For daily use get PS3 performance and get some negative camber setup -1.3 to -1.6 if you want to attack corner. if for time attack in track many real semi slick can go if budget limited go toyo R888.
Isn't semi slick more costly, many use extreme level only....RS-R, AD-08R, KU-36, RT-615K, NS-2R, and 123
awan88
54
5
1,508
Klang Bukit Raj
im sorry, the review i read before is ns2, and my bad this is my first time looking on ns2r at google, what a nice thread pattern, where shop sell this tyre? do u know how much for 205/50/r15? or 195/55/r15?
---------- Post added at 11:32 PM ---------- 6 hour anti-bump limit - Previous post was at 11:29 PM ----------
hahaha, i did think like that especially after the side of the tyre 'botak' earlier than the center.
---------- Post added at 11:34 PM ---------- 6 hour anti-bump limit - Previous post was at 11:32 PM ----------
whoa list of all good performance tyre, this is what i want for here, thanks vr, after this sharing the price from low to high please:driver:
NS-2R I think only have 195/50R15 and 195/55R15.
Since you looking for extreme performance tyres, you can try
Acanta Autotech
No. 37 & 39, Jln. Tasik Utama 3, Medan Niaga Tasik Damai, The Trillium, Lake Fields, 57000 K.L.
Phone:03-9054 5089, +6019-3301689, +6016-2323110
Not many shops stock extreme tyres like this shop....:driver:
xbalance2002
1,501
349
1,683
yes semi slick is costly but as i say budget limited go Toyo R888 as they have different tread wear to choose depend to track surface.
the list your provide some tire easy to get i think AD-08R & NS-2R with 120 tread wear nice tire for track use.
KenDiriwan
1,283
225
Acanta Autotech
Mainly because boss an extreme person himself. LOL. Btw can whatsapp Acanta for pricing too.
Corson
Apr 1, 2014
37
508
www.facebook.com
Acanta Autotech
How much for the tire? I want to change soon
awan88
54
5
1,508
Klang Bukit Raj
walaoweh, ns2r treadwear only 120? hurmm. must think twice for daily use :hmmmm:
always have pro and con for the good tyre. :(
---------- Post added at 10:11 AM ---------- 6 hour anti-bump limit - Previous post was at 10:09 AM ----------
once u kno the tyre size and price, please post here for my knowledge too :P
Stanley ... notice those brackets welded in to the damper bodies? This is where the brake hose normally mounts, and is held in with a clip.
A lot of aftermarket stuff doesn't take this into account. How about your Titans?
I had a bad experience once when I 'DOWNGRADED' to braided stainless steel covered teflon/nylon lines, and the cable ties they used to hold it onto the damper bracket came loose. The line then rubbed against my wheel until it burst open, and I lost my brakes and had to...
