My guess.... Cap leak badly and you now hv broken connections somewhere...Dear All,
I have ECU P30 engine light on, swap ECU tested ok, faulty ECU all the caps,QM3,IC17 changed still engine light on can't start engine pls any advice? Thanks
Rgds
fcwee
Dear E-Tech,My guess.... Cap leak badly and you now hv broken connections somewhere...
Base on picture.... ic17 need change again.Dear E-Tech,
Below is my ECU P30 Pictures, we recheck the PCB trace look like good condition, Beside broken connection have which component can cause the engine light on can't start.
(All the caps,QM3,IC17 Changed)
Rgds
fcwee
Picture plzzzzzzHi guys, really need help on this, cel 14 on p08 ecu, confirm ecu as chage other p08 will be fine, changed all caps and 3leg transistor still hunting idle and cel 14, (cel trigger after few seconds after start) my problem is similar to all cel 14 in this thread since page 1..
Any help would really be appriciated,
Thanx and regards...
Edit: had clean the board btw but still no luck..
Does the check light go off?I have a p28 ECU and its not priming my fuel pump or starting the car. i know its the ECU cause i swapped in the stock one into the car and fuel pump primed and started the car. I read some of this thread and its a common problem on this ecu. the fix is to replace QM1,2 (STA460C) and QM3 (STA413A), IC17 (TA8903SN) c14 or any burned caps. There is no visible burns and all the solder points look intact and good. I went to a electronics shop thats sells circuit board parts and tools ect. and also does repairs and said all the solder points and nothing looks burn but one of the parts i need could be burned and cant see it. They dont have the parts i need. Is there a reputable place to get these parts online? If i replace any of these will the tune on the ecu be altered? will i have to retune? Any help or info on this is appreciated..thanks
hey E-tech great thread you've started here! i have a p28 or p06 (not sure no label) ecu simular problem as diode210. i know for sure that pin A25 pin out shorted to ground and caused the problem. i do not see any shorts in board.
step 1 :when I first attach the ecu it will prime the fuel pump and cel stays on and no start .
step 2: if i key off and key on the fuel pump will not prime and cel stays on no start .
step 3:if i remove the ecu and re install the fuel pump will prime and the cel stays on no start just like step 1
. i have swapped for good known ecu and car will start.
i have measured the voltage coming out of IC7 pin 32 to Q10 pin 1,2,and 3 and they measure 5 volts with step 1 and 3
with step 2 measuring the voltage out of IC7 pin 32 to Q10 pin 1 has 5 volts ,pin 2 has 0 volts ,and pin 3 has 5 volts
My fuel pump doesnt prime at all even if i unplug and plug in the ECU.hey E-tech great thread you've started here! i have a p28 or p06 (not sure no label) ecu simular problem as diode210. i know for sure that pin A25 pin out shorted to ground and caused the problem. i do not see any shorts in board.
