Cheapo like me sure park under the sun.Don't park in the hot sun everyday ler....if you do then use a belt holster or keychain...better than kena chop these days not safe anywhere...My friend carry chota daily wan...
Then you better plastidip whole car then paint wont damageCheapo like me sure park under the sun.
Even if the sudden changes of temp, it will effect your cabin pressure.Then you better plastidip whole car then paint wont damage
Pressurized Sprays best not be under the sun for too long, even plastidip I dare not
put in the car if it is striking hot in the afternoon under the sun.
I might consider getting a pepper spray too then. No energy needed to retaliate.
just spray.
That's why dont keep at hot place as per advised by the instructions on the CansEven if the sudden changes of temp, it will effect your cabin pressure.
problem is buy already, put in the car, after some time forget about it already......:sleep:Then you better plastidip whole car then paint wont damage
just spray.
Pepper spray dun put in the car adi lo bro, bring along with us in our pocket or canister will do.problem is buy already, put in the car, after some time forget about it already......:sleep:
Have to make it a point to carry to and from, if not go home, sure forget to bring out, just like leaving in the car....Pepper spray dun put in the car adi lo bro, bring along with us in our pocket or canister will do.
No point to buy then keep in car, cant use
Confirm the pepper spray can no longer be use and more as display unless her car is always shaded.Better not put any pepper spray in our cars. The can instructions say to store in places no higher than 120 deg F which is 48 deg C. The ambient air inside the car cabin (with tinted windows) can reach up to 50 on a hot day. I got this info from two separate tests in local Malaysian conditions.
Worryingly, I also read from the net about people's experience that their pepper spray canister leaked inside their car. They didn't explode like a bomb, of course, but they leaked the fumes into the car cabin. This happened in the US (summer). If it can happen there, I think it can certainly happen here too.
I am sure the true safety limit for the temperature is higher than what is stated in the can but I rather not risk it. Scared I might get self-pepper sprayed while driving one day.
However, I did find out that there is one brand of pepper spray that can be stored in slightly higher temperatures but that isn't sold here. Also, during the Safety Campaign Demo I attended, someone mentioned she put 4 pepper sprays in her car! One at each door...
It doesn't have to be directly under the sunlight (though direct sunlight will certainly increase the risk of leakage). The dashboard temperature can reach as high as 80 deg C! But ambient air max 50 or so deg C.Confirm the pepper spray can no longer be use and more as display unless her car is always shaded.
Under the sun, it will already be faulty. Correct me if I'm wrong.
Yeap, the changes of cabin(air tight), can increase the pressure greatly.It doesn't have to be directly under the sunlight (though direct sunlight will certainly increase the risk of leakage). The dashboard temperature can reach as high as 80 deg C! But ambient air max 50 or so deg C.
Pepper spray is more of the smell and not the liquid. The liquid is not some kind of acid that will damage or do harm to our skin.Do not put pepper spray in the car, once the pressure builds up, u know what will happen right?
when the fumes attack the car... that is when trouble happens.
One thing about pepper spray, what happens if? the robbers or thugs manage to take the pepper spray away from u??
a possibility.
Since we learn to spray in face? Is it possible to spray below? at his balls?
I am sure it is damn irritating.. sure naik bike also sakit like hell..
They do sell practice canisters (filled with water), but not easily available. I got mine for RM15 during the Demo campaign.Problem is cannot even test. Once used not much left.....
I know you posted before. What I meant is don't know the real one in working condition or not.....They do sell practice canisters (filled with water), but not easily available. I got mine for RM15 during the Demo campaign.
Test a bit ... and use before expiry. The canister weight would also tell if it is nearly empty.I know you posted before. What I meant is don't know the real one in working condition or not.....
