4AGZE supercharger upgrades
dnesh.black
From Facebook
Oct 13, 2010
2
www.facebook.com
Hey guys, Im runnin on Toyota LE AE80 with 4AGZE in it.. Im new to this supercharge engine and just want your opinions on what are the upgrades can be done since im not really satisfied with the speed of it. Thanks
Oct 2, 2009
1,503
Kuala Pilah, N9
My car is Corolla Se limited with 4AGZE.... It has Hi-Cam and adjustable cam pulley... dont know what brand since it has already installed by previous owner.... can go to 200km/j very quick n only at 5000 rpm... can ' main cucuk-cucuk' with brand new BMW and mercedes at the highway.... imagine 15k car can follow 150k car... haha.... olnly its sound so damn loud when it go fast..(exhaust brand dont know also -2.5 inch piping)... just remember to add speed cut/rpm cut. afraid engine will blow..:driver:
nappx
2,532
185
5,163
kLaNG-kEy_tEE
that BMW don't want waste their time only...just think if the suddenly want play a fool with you or he brake or might be emergency brake...then you hit BMW car...at 200km speed i believe damage quite extensive...just think..what will happen..
15K insurance can cover 150K car damage? ahaksss...or never think about it..(just little opinion)
treadstarter..can do p&p, engine balance, upgrade clutch, hi-cam upgrade, find aftermarket ecu or stand alone, remove speed cut, upgrade brake system...anything lah as long as you got MONEY..
Oct 2, 2009
1,503
Kuala Pilah, N9
I didnt say i can race with that BMW.... what im trying 2 say is i still can catchup with the BMW that driving fast in the highway with my small 1.6 engine... and i know BMW is faster... just giving the idea to threadstater how fast that engine can go base on my experience....
dnesh.black
From Facebook
2
www.facebook.com
maintain supercharger & add turbo..
prepare RM only
Not really looking forward to bolt on a turbo cuz im already using a satria turbo for more den 4 yrs..
Jz bought this car as a weekend car to feel the touch of supercharger bro..
---------- Post added at 03:18 AM ---------- 6 hour anti-bump limit - Previous post was at 03:15 AM ----------
Rather den highcams and pulleys, are the others stock on yr engine?
Fuel pump, injectors, fuel reg perhaps?
---------- Post added at 03:19 AM ---------- 6 hour anti-bump limit - Previous post was at 03:18 AM ----------
Thanks bro :)
cefiroautech
301
2
Hi dnesh.black,
You are using 4AGZE engine from AE92 or AE101? Btw, I suggest you to upgrade engine head to MR2 4AGZE wider intake manifold compare to original AE92 & AE101.
If you are using AE92 4AGZE then you may upgrade to AE101 4AGZE Cod Rod to increase HP.
I m ex-owner of AE92 4AGZE, i have those parts on stock, if you interested please pm me for detail.
scoupe
1,087
37
5,148
shah alam
well u could go get the pulley kit, it will give u more boost.. in return ur life span of the charger will reduce. when u run higher boost dun forget to mod the abv or else it will still limit u at 10psi! the gzes are great engines and relatively strong.. have fun man..
3zz
118
45
any ideas how to increase top end power? my 4agze power just limit till 5.5k rpm then the charger feels out of breath
scoupe
1,087
37
5,148
shah alam
there are main reason for the 5.5k power issue is the ecu. it retards the ignition timing cause as the charger vibrates it detects it as knock. i have done many research on this.. not all gzes face this problem. one guy managed to solve the issue by placing a resistor after the knock sensor. the resistor rating i have forgoten. the other way is to go emange:) definitely u wont have this issue:)
how about upgrading into estima SC unit?
btw..anybody got or knew where to source for TRD 4agze new clutch plate unit???
Hi guys,
Keep date open for Lube sales at UMW. Usually will buy every year if free to go...
26 June - 1 July 2013
