1JZ VVTI users
TRDtezza
64
1,508
Sabah
guys ,
I need to know , does your altezza fuel gauge , water temp and oil press working?
Although i got a aftermarket water temp but my fuel gauge seems to be acting funny.. It only goes up but not down . The only way to get it down to where exactly my fuel is , is to unplug my batteries. Then it'll drop to where it is suppose to be but it'll stay there.. I heard something about lowering down the voltage to the meters if you are a 1j transplant , is it true ??
AE111_SEG
1,024
180
Putra Heights
sorry.. not very familiar with 1JZ. Maybe IJZ bro can help. The have quite alot of experience in 1JZ conversion.
Mic Tie
From Facebook
Aug 25, 2010
152
10
www.facebook.com
guys ,
you got my pm:listen:
wfhan
4,339
96
selangor
trdtezza, your neck will get very long waiting for the brotherhood of 1JZ to reply.. :P
they are very busy in R&D of 1JZ and less time to online here.. :P
icon86
117
5
3,018
Klang
Doing some research on Altezza, which is the most suitable 1JZ vvti halfcut for Altezza?
green
326
25
3,028
kl
there is a lot of 1jz vvti versions from the jzx100?????
there is only 1 version. the 1jzgte vvti jzx100(single turbo) and yes this will be suitable
you can put in the old jzx90 1jzgte non-vvti(twin turbo) as well.
icon86
117
5
3,018
Klang
According to my research, ABS pump, ECU & battery position is different from altezza.
Altezza's ABS have 2 types, I would prefer to use back the JZX100's ABS but its located at the other side of the engine bay.
1JZtezza
371
42
Hi,
Welcome if you are new owner!!Sift thru some earlier threads here if you are serious on conversion.
You will also know where to find us!!
icon86
117
5
3,018
Klang
Hi,
Great to know that, I need more info on 1JZ. Actually I've already done the conversion, but its a 1JZ-FSE. Now planing to smack in a manual gbox.
---------- Post added at 10:21 AM ---------- 6 hour anti-bump limit - Previous post was at 10:14 AM ----------
According to my research, I think the JZX110 is more suitable, but the major problem is no one actually brings in. Too new & expensive I reckon.
---------- Post added at 02:38 PM ---------- 6 hour anti-bump limit - Previous post was at 10:21 AM ----------
Green: U shouldn't have delete your post, I would like to explain & learn more. Between 1JZ-FSE & the GTE is a different technology. My only concern is the fuel consumption
But anyway like I said, like I said i'm just doing some research.
stepwyew
448
15
Bro ,
Just check with you why JZX110 is more suitable and not JZX100 ? just want to know only
cheers:driver:
icon86
117
5
3,018
Klang
Bro ,
cheers:driver:
I'm not sure, thats why i'm asking around for answers.
But I've discovered there are few things JZX110 & SXE10 share in common, such as:
- ABS pump
- Battery
- ECU
As for JZX100 ECU located inside the dash, unlike the JZX110 ECU position is just plug & play.
I might be wrong, but do correct me if i'm wrong.
Please refer to the picture below.
1JZtezza
371
42
your pictures showing 1JZ-GTE and not 1JZ-FSE.
1JZ-FSE is the 'economy' version (eg.3SG v 3SF)
If running well why want to change manual gearbox or mod some more???
I am lookin for a gearbox that will last...Now I have broken 3 gearboxes and 1 longshaft this year. Only 1 i CAN FIND IS DONE BY PPG AUSTRALIA costing me RM 30,000 approximately. Also titanium or carbonfibre shaft only from America. So if anyone can tell me where i can find something similar that can take the horsepower ?
