what should do after engine transplant??
steven5899
9
Hi all...
Recently I just have my engine transplant..my car is nissan altima u13. i transplant sr20neo vvl with cvt 6 speed gearbox. Wonder what next should i do.. I not means those JPJ, Puspakom things.
The concern thing is should i do any tuning of that engine ? or any others thing.. pls advice me. tq.
Hi all...
The mechanic who did the transplant did not tune it up?
Probably your suspension and brakes upgrade....
ddv_nk12
1,228
236
663
PD
If not yet tune, I suggest to run in first. Then only go dyno tune. While running in, don't rev too high. Drive slowly.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Before attempting doing extensive mods, I would try the new setup for a couple of weeks, after all, it's a used engine and transmission. This would help you understand it better and you can also identify the areas (if any) that needs attention or replacement parts, especially within the transmission. Easier without the distraction from additional mods.
DanzEterna
15,911
3,371
www.primeperdanaclub.com
run-in your engine for a few km's to ensure the engine & gbox is working fine.
u need to upgrade your brakes, preferable 4 pots are now quite cheap, u can source from either skyline R32, or silvia s13 or 14. bout rm300-350.
2nd upgrade your suspension to adjustables.
steven5899
9
thx for the feedback. actually i already run that engine quite a while already.
my main priority is not to race. i'm more towards to comfort type. i just want my car to be more fuel efficiency. Currently my car is doing 1 liter= 8km , somemore is slowly drive. I know this could be better because it is a 6 speed cvt gearbox. But my gearbox got some problem. During cold start, the moment i enggaged gear, it will response immediately. But during normal time, it take about 3 seconds to response no matter engaged to D or R. Any idea of it and any advice?
This is signs that the wrong oil was used to fill the CVT gearbox. CVT gear oil is significantly more expensive than SPIII, Dexron, etc. Perhaps about the same as Mercon though. The previous Honda City with CVT owners skimped on the CVT oil cuz it was almost twice as expensive as normal oils. Old skool mechs usual reply "can use one la" didn't help either. Within 2 years their GB would die and now a lot of those Citys are in 2nd hand car dealerships with bad GBs.
Yup, CVT gear box have to use CVT fluid and not ATF...
steven5899
9
LOL.. i thought ATF that mentioned is the gearbox cooler.. blur blur..
actually i using cvt oil NS 1 which stated at the gearbox oil dip since the transplant.. for ur information, i do have the gearbox cooler in my car also..
---------- Post added at 12:03 PM ---------- 6 hour anti-bump limit - Previous post was at 11:59 AM ----------
And sometimes when i using D gear by pressing brake during traffic lights, or in junction road, the moment u step on the gas, it like no response at all..and i have to step one or two more time, my car only go..
Could be your TCU that needs troubleshooting. Better go to a mech that has the diagnostic tools that connects to the TCU/ECU and figure out what the problem is from there.
Hi all, this is going to be abit long, so I'll use alot of paragraphs for easier reading, ok?
I drive a year 2000 Putra. I just changed my ignition key to those "ball bearing" key system. The reason is because on last Saturday (30/9/2006), my Putra was almost stolen. This happened at the road going upward, that you can see when you exit from Endah Parade main entrance. I parked further up the road, where the road bends alittle bit. Becareful when you park here...
