subaru ver 9 vs mitsubishi evo 9...which car is much better??please help me...
Yee
654
34
3,028
Anton Lavey
Evolution is more straight forward compare to Impreza. JDM STi version 9 alone (which is actually refer as JDM MY06 & MY07) has atleast 8 different specs, example WRX STi, STi Prodrive, STi V-Limited, WRX STi Spec C, WRX STi Spec C type RA, WRX STi S204, WRX STi A- Line, and ultimately WRX STi Spec C type RA-R...all these are JDM and every each of them have some differences. Also, USDM STi which came with 2.5L engine and different specs. You may look into these different options in future.
There are also very nice Recaro CF seat for S203, and S204 which cost about RM 20,000 per seat. while RA-R came with a Recaro RSG optional full bucket.
In terms of handling..learning to track and power slide the 4wd is fun and challenging.
STi Disadv: Mech and Tuner
Iszo: S203 is the one similar with version 8 front (MY03-MY05), whereby S204 has the similar front as version 9.
p3jal
1,493
183
Selangor
ya i ride motorcycle only for going work. easier =D . i currently drive e7.now collect fund upgrade engine. =) for both car also have advantages and disadvantage
6UE5t
6,000 RPM
6,756
1,300
Yeah, that's another thing I don't really like about the WRX, just too many versions, as if they keep upgrading it bit by bit once they found out they lost to the Evos of the same release until finally they can match/beat the fastest Evo version. Need the more higher spec/hardcore WRX in order to match the Evos with much less versions. Nonetheless the WRX is still a great car and very close second in terms of performance value for the money in the auto world. Can't wait to see the next gen to be released, might change my opinion for the first time since the 22B STI.
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
I see. Usually people say Evo 7 is the weakest evo but still, an evo is still powerful in it's own way. Anyway, how did you feel about your evo?
6UE5t
6,000 RPM
6,756
1,300
Well at least not anymore after the Evo X came IMHO! :) Before that, the weakest Evo are the VII GT-A and the IX wagon A/T. Initially when the VII released, people a bit skeptical especially after the awesome TME since the VII looks much softer and also heavier, but actually it holds its own fine among the others.
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
TME is always the legendary evo. Incredible performance and famous. Probably a good match for Evo 9 MR.
Technically SST is way faster.
Technically it is, but that is not really the case in real life. Have a look at this
Mitsubishi Lancer Evolution X - The Battle - Best MOTORing (Japanese) - YouTube
ColdPlay
288
112
1,543
Both are awesome car which offer driving satisfaction that far exceeds the worry on maintenance.
Evo has more aftermarket parts to play with but the scooby hold itself better in handling department.
When both are almost a tie, the simple advantage could be a deciding factor, depending on individual preference. And I am on the Scooby simply because I like the boxer's growl.
6UE5t
6,000 RPM
6,756
1,300
More head-to-head comparisons
[youtube]8oSz38uanlY[/youtube]
[youtube]D7DnQUzjb50[/youtube]
[youtube]RJJHeQhip0s[/youtube]
Haiya...
I give you the best Evo/Scooby, you'd still lose to a Wiralution if the Wiralution driver is experienced and skilled.
Who cares what you buy? If you don't utilize it, it'll be nothing more than a sedan with potential.
So just buy whatever you want la. This 'my balls is bigger than your balls' debate will never end. Both cars are nice, both cars have their flaws, both cars suck balls to the Audi RS4.
Period.
:thefinger:
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
Never ending rivals. I prefer Subaru somehow more than an Evo. Not because is better but I just somehow prefer it over Evo.
The only Evo I like is the Lan Evo. :biggrin:
Audi RS6 :love:
Good night
I have a Colt GTI 95, engine 4G93 DOHC and I will review the motor, I'm looking to increase the compression ratio, I will use ethanol.
What is the minimum thickness in mm of the head gasket that I can use?
I use the pistons of the SOHC 113cv 4G92, without colliding with the valve piston?
http://www.allpartsnet.com.br/produto.php?prod=3400&aplic=1323
Looking forward
