is it possbible to DIY lowering the front part of the bonnet? I mean like tilt a bit lower down... cause my engine so damn dirty la... cannot tahan... worst thn WRC car(heh heh)
i think wut he meant is do like mivec bonnet...which is to lower the front part of the bonnet in order to reduce dirt from goin into his engine bay through the grill...i think tat's wut he meant...i still dun reli get wut he reli meant...=(
so..it's like wut i said???lol...seal the gap wif sum rubber thing la...or use superlon..alang alang...soundproof ur whole bonnet...and cover the gap...2-in-1
yeah yeah... jz seal the sides of ur bonnet lo... should be better kua... no need so much hassle do all those welding and stuff to make ur bonnet lower...
I plan to go with S90 @ 70mm throttle body and aftermarket aluminium intake manifold to match with my Deratech cam.
Meanwhile, is upgrade on air flow meter is necessary?
If needed, what is the air flow code number is good to upgrade?
Also, changing in bigger air flow meter will make the engine run lean ?
Please advise and educate... Thx.
