Installing Mivec Block to my 4G91..
Aug 23, 2010
kuching
Anybody ever try to install/replace their 4G91 block to mivec(high compression) block? Will it be ok?? anybody face any problem after replacing it? coz im planning to do it soon... Advise needed here. Thanks...
apai_Ngage
337
Can pnp mivec block to 4g91?
speed2horizon
2,798
334
1,683
There's no actual meaning of doing so... U can actually go for a 4G92 SOHC block, which cost less than half of MIVEC block. Still, U'll achieve 10:1 CR.
If u gonna use a MIVEC block, the 11:1 CR will require a larger injector to prevent premature detonation. If u were to upgrade, why not straight go for 4G93 SOHC block which cost the same as a MIVEC block. It's also plug n play. Just use back ur 4G92 oil pump. At least U'll get a 1.8 DOHC. Just my 2 cents suggestion.
Yes. 4G9X are all the same. Difference is only SOHC or DOHC. If u are replacing the whole short block.
Hi,all...
Curently i use my Putra as daily drive..the engine now is getting tired. :mad: I'm thinking to do hybrid 4G93P + MIVEC. How hard this hybrid actually? And what are the parts from MIVEC (4G92) have to use? As i know the whole thing from the engine head up have to use plus wiring hardness and ecu. It is true?
Hope,if anybody have done with this hybrid can share the teory... :biggrin:
