HELP!!! Wierd Diving Noise
cybtech
408
6
Calling all sifu's........
Need some advise, (i'm using BT 6spd @ EE101)
when i starting to accelerating at 1st gear, i heard a few "thumps" near my front left tyre,
2nd gear still got "thump" if accelerate very hard. 3rd and so on no problem.
The condition is like this,
the car is static, put in gear 1, then accelerate, when fully release clutch, the front left tyre like wanted to do abit of tyre spin :burnout:(donno can't see when i'm inside the cockpit) then hear few "thumps" (thuk...thuk....thuk) ..... sort of like terlepas from drive shaft but not sure.... So i need anyone advise....
This started when i ran over a puddle of water.:banghead::banghead::banghead:
Thank you in advance. :adore::adore::adore:
cybtech
408
6
B
M
U
P
anyone???? is it the mounting??? suspension??? help:bawling::bawling::bawling:.....
cybtech
408
6
thanks bro,
anyone got encounter this kind of prob b4? or i'm the 1st one......:bawling:
wfhan
4,339
96
selangor
maybe u are the first one.
how about decelerate ? when u brake during cross over road bumps got the sound or not?
but my guess is same as laichong's
cybtech
408
6
well, while braking hard/normal no noise,
i know what u r refering to, go uphill downhill or bumps..... no "thuk-thuk-thuk"
but the wierd thing is only happends when i start to accelerate.....
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
just join in any available TT so other can try to feel it...
there's tons of possibilities...
maybe ball joints, drive shaft, lower arm, bushing, suspension and so on...
chinozie
3,429
170
5,163
Damansara
have you jack the car ?
see if any unusual thing...
once you have securely jack the car...
try to imitate the problem while your wheel on the air...
narrow down the problem...
good luck...
laichong
269
Kepong
its sounds more like the tooth of either the drive shaft or knuckle is worn out... but that just guessing lar... better take out and have a look....
cybtech
408
6
Thanks guys,
i'll jack it up, and take a look,
once narrow the root caused of it, i'll let you guys know...:adore:
cybtech
408
6
Hi guys,
it's the mounting,
the front mounting (near extractor) the rubber..... gone!!!
donno how/why it's gone........:bawling:
now i'm calling again to all sifu's or chop shop kaki, :adore::adore::adore:
what is the price of the mounting new/chop condition???
Hi all,
How do i modify the iginition port to connect to a switch to make a separate starter? My car is kelisa. I did unplug the port and find out that there are total of 5 cable in a port. Can i know which cables are used to iginite the engine to start??? :)
Thanks to all in advance~
