- Sep 12, 2008
- 55
- 1
- 1,508
last time i asked a local spare part shop is around 400-500 for a genuine OEM O2 sensor.Wil try,tq Levin 818,by the way,didt u have o2 sensor for bt?
E-manage can solve power delivery/smoothness problems due to slight fueling mismatch when convert from SVT to BT ecu(with trumpet)..but i always want to make sure all sensors and actuators are in good condition before proceed to something else.We need to address the root cause 1st.If all things in good condition,then use e-manage to smoothen out all the problems.One more question,if I use emanage blue to tune up,the problem can be solve?
Sorry I don't have it. Now a days it is hard to get a used O2 sensor as most of it will be removed from the H/C in Japan. This is what Mun Lee Auto Parts informed me.Wil try,tq Levin 818,by the way,didt u have o2 sensor for bt?
I fully agree with this! Always solve the problem before plug in any piggy back to fine tune the performance.E-manage can solve power delivery/smoothness problems due to slight fueling mismatch when convert from SVT to BT ecu(with trumpet)..but i always want to make sure all sensors and actuators are in good condition before proceed to something else.We need to address the root cause 1st.If all things in good condition,then use e-manage to smoothen out all the problems.
check fuel delivery system.clean throttle and ISCv
My A/C amplifier was taken from SVT first gen M/T. It communicates well with all the SVT ecu that i have plug in, regardless which generation, A/T or M/T... Perhaps, your case is coincident, or the wiring that you handle already modded before arrive your hand... :hmmmm:Wong,yes you're correct...if your wiring is SVT auto,then it would not have a problem to accept BT auto/manual ecu,also the a/c will not affected because the SVT auto a/c signal to the ecu is same with blacktop auto/manual.
The problem only when converting SVT manual to BT ecu,but so far i've done almost 20 SVT to BT conversions,so far no customer complaint on low idle,for such conversion,it is necessary to use a/c idle up valve.
And also when convert to BT ecu,some may go the 'trumpet' route,hence the low end fueling is greatly affected,a fuel pressure regulator will usually fixed this.Also i will suggest to each customer to fit blacktop O2 sensor for proper running (although most of them didnt bother)..
Those are still from same manufacturer with similar grade. Which mean will have problem after 15 yrs later...I think the caps look different than the earlier svt ecu isnt it Wong...
bro..i hv try to change AFM unit! result is idling is better than B4 BUT it juz can last for 1 or2 day onli after tat back to worse!! then after tat i try to UNPLUG the FUSE BOX ENGINE CONTROL FUSE(15)and RESET it...after tat my idling was normal againt BUT it will back to worse after FEW HOUR or OVERNITE.... anyone know wat happen!!ALEX KHOO,
if i'm not mistake, i think ur AFM sensor is faulty. last time i also have found this issue before, after clean ISC, throttle body more than 3 day, the idle problem coming back again. after i tries to buy another chop shop AFM, and tries to adjust the bypass screw at the AFM (chop shop), until now more than half years so far no problem.
after reset morning start 1200-1500rpm then slowly drop to 900-1000....after drive few hour or overnite start 1000rpm then drop to 400-500rpm then sometime mati engine!! i hv adjust angle of distibutor abit higher but same!! wat is fico part?hi alex,
how many idle rpm during cold start engine? for my case, i had to tune fico part, angle of distributor as well. did u tried as i mentioned part?
tat day i take my car clean 4 throttle( take out piece by piece) by bro LEVIN_818! he oledi check all the vacuum hose where dry and crack ,then change most of it...but after drive 1 or 2 day,the problem came back..Bro alex, how was the problem? Today when I popup my engine hood, take short look at all vacuum hose around charcoal canister. What I found is 2-3 vacuum hose already cracked. I'm gonna replace that soon.
Since your engine is almost about same as mine, why don't you change all the vacuum hose.
Cheap trial and error only.
AFAIK, vacuum hose behind 4 throttle has been changed rite?
