I faced this problem a few months ago. Now solved already. I think mine was more severe, all 5 head cover nuts were covered in oil (my engine is a weak D16Y7 non-vtec ). The problem with most honda head cover is that the thread in the head itself is not through-hole type. Meaning that, if the seal under the nut is weak already, no matter how tight you torque the nut it will still be covered in oil. The solution: replace all the seal and put some new head cover gasket for good measure.
Maybe the thread loose already? If it is, go find workshop that has tap & die set, the thread can be re-threaded. You'll have to use slightly larger nut after that.
Guys , I am organizing a track day which was initially private but due to many last minute cancellations. I am opening up the slot to public. Currently there are about 20 slots left. First come first serve basis...
Swiss watchmaker Tissot celebrates 10 years of being the official timekeeper for the MotoGP championship this year. In conjunction with the occasion, Tissot has also...
