I faced this problem a few months ago. Now solved already. I think mine was more severe, all 5 head cover nuts were covered in oil (my engine is a weak D16Y7 non-vtec ). The problem with most honda head cover is that the thread in the head itself is not through-hole type. Meaning that, if the seal under the nut is weak already, no matter how tight you torque the nut it will still be covered in oil. The solution: replace all the seal and put some new head cover gasket for good measure.
Maybe the thread loose already? If it is, go find workshop that has tap & die set, the thread can be re-threaded. You'll have to use slightly larger nut after that.
Mini’s return to the rally stage has shifted into top gear with some official shots of its Countryman World Rally Championship prototype beating at the dirt track of...
Hi guys...can anyone tell me how to diy dismantle wira dash and install mitsu dashboard??? how many screws??? where?? n one other thing...can we use oem blower with mitsu dashboard???
