I faced this problem a few months ago. Now solved already. I think mine was more severe, all 5 head cover nuts were covered in oil (my engine is a weak D16Y7 non-vtec ). The problem with most honda head cover is that the thread in the head itself is not through-hole type. Meaning that, if the seal under the nut is weak already, no matter how tight you torque the nut it will still be covered in oil. The solution: replace all the seal and put some new head cover gasket for good measure.
Maybe the thread loose already? If it is, go find workshop that has tap & die set, the thread can be re-threaded. You'll have to use slightly larger nut after that.
i would need advices on eci multi intake manifold conversion. I'm now currently using thai made intake manifold, the throttle body seems to give me some prob, that's why i thought of converting to eci...
Want to ask about the GTT normal oil pressure?
1) when the car idle, it is below 4 or above 4?
2) when normal driving, it is below 4 or above 4?
3) when high rpm, it is above 4 or below 4?
