Emanage Ultimate - Guidance
AD_EG
6,000 RPM
6,328
231
Ipoh
Hi bro's.
just need some advice or help using the emu.
1) The emu is already tuned by a tuner. i wanted to run a datalog, so I connected my laptop to my emu, and a popup came up "Import data from emanage" and i clicked ok. My question is, does this reset the emu to a default tune? is there a way i can confirm or see if the car is still tuned?
2) the datalog function, how do i read it? or what can i see ? can i check if my airflow sensor(maf) is faulty through a datalog?
appreciate any advise. this is a brand new world for me.
dneilmotorsports
121
11
518
perak
When u connect to the ecu,u will see everythings there. Since the tunner not locked the maps.
U can see all sensor input run when u datalog the ecu while ur engine running. Actually the datalog use for tune not for read fault code..
AD_EG
6,000 RPM
6,328
231
Ipoh
bro the pic too small i cant see anything. but i thought there was a way you can read the signal reading or something like that to indicate something that is abnormal?
AD_EG
6,000 RPM
6,328
231
Ipoh
ok, so bro is there a standard voltage expected out of the sensors to be considered as normal or abnormal? in particular i need to know the afs.
dneilmotorsports
121
11
518
perak
OK. what is ur problem actually? Standard voltage of sensor depend at what kind of ur engine use.. Normally for hondas map sensor will read at 0.50volts at-12.8psi/meanwhile at full throthle it will read 3.41volts at 2.7psi. If i not mistake.
AD_EG
6,000 RPM
6,328
231
Ipoh
sometimes when rpm reaches 5k-6k cant climb anymore...like cant go.. engine is 4g63t ... want to check if my maf is faulty or not...
AD_EG
6,000 RPM
6,328
231
Ipoh
the emanage using long time alr bro... recently only this problem happened. engine light not on...as i know..maf sensor starting to have prob might not have engine light still can be problem...thats why i want to use the datalog function to see if i cant identify if there is a problem there to make my troubsleshooting easier.
dneilmotorsports
121
11
518
perak
u should try drive ur car and floor the gas while u datalog.Record it,then u see what karmanHZ input & output at where the rpm stall..
AD_EG
6,000 RPM
6,328
231
Ipoh
thanks bro....will do tomorrow night and post it here....
AD_EG
6,000 RPM
6,328
231
Ipoh
bro ... before doing the datalog run tonight...i cleaned my MAF(afs) and washed my filter, re-installed... tested the car and did a datalog..but the problem is gone... doesnt hesitate anymore.... so i think my afs was the issue.... thanks bro for your help.
AD_EG
6,000 RPM
6,328
231
Ipoh
the problem started again last night... rpm 5k+ rpm...will hesitate.. i think maf sensor problem.
AD_EG
6,000 RPM
6,328
231
Ipoh
time to run on map..hehe
yup you are right bro... reading up on this... new maf costs rm1200.
any idea how much does a greedy 3 bar map sensor cost?
AD_EG
6,000 RPM
6,328
231
Ipoh
halfcut ah bro? i check with bintang brand new maf #286 1.2k.
your link is for ignition harness bro, i need the 3 bar map sensor right?
ehdrian
I Don't Care!
3,310
280
1,683
Penang
no la, new one..oops, sorry, tersilap pulak..
FTZone selling rm320 (016-4786000)..can check with him n c
AD_EG
6,000 RPM
6,328
231
Ipoh
thanks bro...will give him a call and see. he is the one from penang right?
Hi all,
I know many of you have come out your own air filter heatshield but may i know where exactly you bought the bracket (those L shape metal with holes) that mount in the engine bay ? Thanks
