Emanage Ultimate
Blood Red
Hi,
I was wondering if any of you have experience with the Emanage Ultimate in your car, specifically on R34 w/ RB25DET engine. Mind sharing your thoughts (pros/cons)?
Also, if you are not using either PFC or Haltech, what are you using and for what kind of set up?
Thank you.
Wassalam/Cheers,
Newbie
Hi,
Thank you.
Wassalam/Cheers,
Newbie
Blood Red - I really cannot promise you that the E-Manage works and even so, it doesn't come with harness. I hope I'm not crossing the line but I feel you should address the current problem before going for upgrades. Until the underlying problem is fixed, I don't see the reason to complicate matters.
But in the interest of discussion, its better for you to list the features you need and then its easier to decide on what's best for your application. For example you might want to support larger injectors, run MAP, have data-logging, use STACK dash or whatever it is and what everyone else uses might not support some functions at all or some do certain functions better than others.
Pimpin,
Yes, will not rush into getting an ECU. The reasons I ask are:
1. PFC for GTT is so difficult to source
2. Haltech is so prohibitive
So, as an alternative, I am looking for something that is around RM3 - 4k all in including installation/tuning that is capable of supporting the following:
1. Bigger turbine, say, GTRS or 3071
2. Bigger injectors
3. MAP or MAF
Personally, I know very little about aftermarket ECUs, thus I have zero clue on what to look for. For example, what is the difference between running on MAP or MAF?
Basically, I want something that can help me achieve mid to long term HP target (300 - 400whp).
BloodRed
very subjective issue when come to ECU selection
Like pimpin say, you need to ask yourself
what you want the ECU do for you before you decide
NOT the ECU can do what before you decide
PFC is hard to source but if not mistaken Vspec have one rite ?
wanna ask something here ... can emanage ultimate remove the air flow sensor for 1JZ ?
coz my intercooler piping was bigger than air flow sensor ... ???
please advise ... thanks.
BloodRed
Cmng,
That PFC is sold.
I understand what you are trying to say. Let me rephrase my question a little bit.
What is the difference between these:
1. Emanage ultimate
2. PFC
3. Haltech
I prefer if those who have used them on RB25, 26 share their experience on the pros n cons.
I can't say what I want from an ECU, thus the thread. I need to understand what I need to control to achieve a HP target of 400.
Thanks.
Cmng,
That PFC is sold.
1. Emanage ultimate
2. PFC
3. Haltech
Thanks.
If only a horsepower figure is all you're after then any of the above will get you there. But naturally one will be better than the other. You're going to have to be much more specific bro to be honest. Until you can articulate what exactly you're after, then you can't really get there can you?
Pimpin,
Then I need help in terms of articulating what I'm after. Ok, maybe it is best for me to share the shallowness of my knowledge on this so that you know where I am coming from.
1. My aim is to have a setup that is responsive and good for GTJ runs over weekends. I definitely do not want something laggy and designed for straight line speed.
2. As I understand it, the following supporting mods are required to support bigger hp:
a. bigger injectors (650cc)
b. bigger FMIC
c. metal gasket
d. fuel pump
e. fpr
f. bigger turbo
g. ECU
3. I do not know the difference between MAP and MAF tuning. This I need help from those who know in here. I understand that some ECU can only run MAP, some MAF, some both.
4. Also, the ECU needs to handle the bigger injectors, AFR, ignition timing, at least. I do not know of other parameters, thus I need help in this area.
Again, if anyone here has any experience with EMU, PFC, Haltech, (or others), do share it here if it is not too private.
I just want to know your experience with your respective ECU with the setup that you run. Perhaps from there, I can ask more question.
Hopefully, this thread will benefit those who are not as knowledgeable as me when it comes to ECU.
Thanks again.
bloodred
if you can wait. perhap another one available since owner upgrading
but i not idea how much he selling
as pimpin say
comparison and feedback is pointless now
now it your budget and your requirement
perhap i can ask some simple question
plug and play ?
budget ?
need to traction control or launch control ?
need to built in boost control ?
need to connect to external display ?
need to run external coil ( MSD etc )
cmng,
Now we are getting somewhere. My answers:
1. PnP preferred, but not limited to, ie, piggy back also ok.
2. As stated, for now 3-4k for now. FYI, I am in no hurry to buy the ECU.
3. Traction control is a must. Hehehe. Launch control - tak mau.
4. No need to connect to external display.
5. No external coil needed.
Btw, why is it pointless to share experience on different ECU and setup? Shouldn't it benefit the forumers?
Bloodred..
different people different requirement
and with feedback on ECU
you can come to some people swear by microtech and some people say it piece of shit
as well same with Haltech and Motec
for me
i can say PFC is piece of shit since it cannot meet my requirement but for other is best ECU for them
the word
traction control and budget 4k is limiting your choice already
it same like i want traction control, launch control, boost control , external coil , external display
so many ECU is out already
and i not yet come to ECU parameter and ECU control. that will make you more headache
Hi Blood Red
You might look at vipec or link stand alone ecu. In term of cost, you can also look at NISTUNE.
For further details, go to "skyline australia" where there are many topics on each specification for ECU and anything regarding to skyline.
MAP sensors runs without any restrictions ..ecu running on MAF still relys on oem airflow ..which is pretty much restricted/safer..running ecu with MAP sensors requires spot on tuning as there is no safety net since the oem afm is removed.zero in what u want, future mods and the most important thing the tuner.
---------- Post added at 05:27 PM ---------- 6 hour anti-bump limit - Previous post was at 05:22 PM ----------
safer bet get the PFC...since a lot of them has experience with it...doc should be able to help.as for me ill go with microtech lt 12 since the tuner is dear a friend of mine and has proven many times more then capable in tuning it.
Sincerely BR, I think E-Manage Blue with ur current Profec EBC is enough to get around 400hp with good selection of supporting mods in ur list.
I'm not going to say for u to go to GTAuto for tuning eventhough they can do E-Manage for u coz some might say I'm biased but as what I've told u and others again and again, do it with the tuner ur comfortable with.
'Comfortable with' does not mean u need to keep seeing the tuner forever as well. If u feel the tuners/shops does not meet ur requirements, then move on. It is not only about hear say reputation but also skill, customer/aftersales service and rapport with these tuners/shops with u as an individual by which u experience first hand.
MAF is basically using the air flow meter (AFM) by which has restrictions on the resulting power output limit, hence some will upgrade to RB26 or even Z32 which enables higher readings. I personally have MAP on both my SR20 and RB26.
So my advice is, u may use the E-Manage Blue as I was quoted somewhere like 1.8k for unit, harness, installation and tuning (other tuners might have similar prices) as the budget is limited.
Of course, best case scenario is to get a standalone ECU so that u won't have to think about piggyback ECU limitations once u want to go for higher HP.
Another thing, to make things easier try to find the best tuner/shop that ur comfortable with and then ask him the best way to go about ur target HP application and budget. I'm sure the tuner/shop will give u the option suitable for ur situation.
Thank you for this.
Besides the tuner being able to tune microtech properly, was there any other reason that you chose it? Im just curious to know.
Nothing matters except for getting it tuned right, u can even run 600bhp with standard oem ecu programmed..most japanese tuner do it . microtech's are proven ecu's able to handle well over 1000bhp ...better resolution compared to pfc.
shark79, yes i know tuning is very important. This part I know.
I am more interested in the latter part where you mentioned better resolution. This is the kind of feedback I'm looking for. You also made the comparison with PFC, which is good.
I can only assume that with more tuning points, with the proper tuning, you'd get most out of your setup. Correct?
Temujin,
You are right as well. I do think the Emanage is more than sufficient, but I need to be sure. Hopefully, I get to leverage on other Skyline owners who have used Emanage, specifically, the EMU. However, it seems very difficult to get this feedback, since I have to specify a lot of things pulak. :)
Blood red
better resolution haltech. motec , aem , gems , autronic , vipec, etc
emanage sufficient but are you happy to see your car full of wiring tapping ?
do emanage fit your budget ? remember to add those sensor, wiring etc as well labour to install
some other question
are you looking for MAP option or retaining to MAF ?
what correction factor you looking at ? ( if you dont understand read the below )
are you looking for exhaust correction factor ?
are you looking for boost control vs RPM correction factor ?
are you looking for additional input correction factor ?
are you looking for 32 x 32 map resolution ?
how many output and input you looking at ?
are you looking for dual map option ?
are you looking for a ECU that many tuner can do only only specific tuner can do ?
The similiar style of question i ask my boss when they want to change laptop before i suggest the right laptop for them
hehehehe
A thread every 60 seconds
