Guys, im in dilemma.im in tight budget, maybe enough for emanage blue but need ur opinions.its for my 4g93 dohc n.a open mod.
Rebore 83mm
4g94 crank lightened
Exedy 3 puck
Pnp head
288 matspeed cams
Jun v.springs
450cc injectors (didnt get 275)
Fpregulator
And many more to list
I need to know if e.blue can support it or not...
Between e.ultimate & microtech which i should pick between price & pros & cons...
Its hard to find mitsu microtech nowadays.
Tq for helping me out
Hi! Ken here...i'm sort of a tuner u can say..
Your car don't have any supercharger or even a turbo...
If you're planning on going to force induction which your standard ECU can't cope, then you may go for the stand alone. Piggy back cannot.
E blue and e. ultimate are piggy back..although i could say the ultimate could actually tune up a bit more. But from what i see with what you list down, E manage blue is already enough for you.
Why wanna find mitsu microtech when you can buy Haltech sprint which can use for all except rotary? Both are still stand alone and perform the same functions.
As far as you maintain with NA then E blue or E ultimate is enough.. more than enough actually..
I did a 4G15 before.. i had more mods than you... i only change to Haltech stand alone after i put in the 4 throttle for cyberjaya drag where i have to cut the rev limit and set it to 9000 RPM... But for now you're still in okay condition... therefore, the max is e.ultimate and the least is e blue. Don't waste money on stand alone yet because they would not do anything extra for you..E manage blue is around RM900 and the Ultimate is slightly around 1300-RM1600.. Stand alone is RM2300-RM2800. Why wanna waste when you can save alot? If it was your friend/mechanic says NEED to put microtech or Haltech.. don't believe them..it's not needed with your current mod.
