Few 100k? some you are suppose to add at every oil change leh.....lolThe additive properties probably wears off, or breaks down too after few 100k drive. Nothing last forever.
Add additive only IF needed. Donch itchy itchy hand.....heheheheh
No lah! actually against it.....loleerk..... why do you guys suddenly decide to add additives anyway...
maybe its time i try as well..... my tappets sounding more and more like a diesel
Not trying to argue if additives are beneficial in the short run or long run or at all here, I'm sure most are scammy than those that work.
But for tappets and old engines, Id recommend Tufoil even if for experimental sake. Could try it say when you're halfway through your engine oil life.
I've used them in my E30 325i for years back in the 2000s
Don't take my word for it though, you should do some research on the product before trying it out.
Speaking about noises, the manual box in my E30 used to chatter for years. I was told one or Redline's transmission additive or was it the entire fluid itself will cure this and it did impressively.
So there is light at the end of the tunnel for old car problems and aftermarket fluids and additives
Sent from my SM-N9208 using Tapatalk
What car? Perhaps it's time to adjust tappets?urgh.... my 20 year old tappets bising!
but ohh well, no real harm i guess...
wrong, nowadays oil is quite crappy, you really think oil manufacturers would add some precious elements into oil? hell no, the truth is that we live at times when oil is getting worse and worse but we can't stop buying it. that's why car's engine can break down so easily, when the car is newAs some have mentioned if the product is so good, oil manufacturer would have added it into their own blend......
Engine break down got many ways. Racing them, no maintenance, etc., MY VR is 16years, Sonata 20 years and Chery is 6 years also no problem and using all kinds of engine oil....wrong, nowadays oil is quite crappy, you really think oil manufacturers would add some precious elements into oil? hell no, the truth is that we live at times when oil is getting worse and worse but we can't stop buying it. that's why car's engine can break down so easily, when the car is new
Yup, car engines break down can be by many reasons, not necessarily engine oil. By right engine oil actually should already be much better or must comply to higher standards than before because engine requirements are also higher: more hi-tech, more power, more fuel efficient, lighter package, tighter tolerances, higher compression, more and faster turbo boost, etc2. you name it!Engine break down got many ways. Racing them, no maintenance, etc., MY VR is 16years, Sonata 20 years and Chery is 6 years also no problem and using all kinds of engine oil....
