Need help from Neo members
Zack Zikry
From Facebook
Oct 2, 2011
14
29
Selangor
www.facebook.com
hi semua, salam 1 malaysia. Saya ada masalah sikit dengan kereta sy. saya guna proton satria neo 1.6 auto. campro tahun 2010. kereta saya ni topspeed 160-165 kmh jea. rpm baru 4500-4600. tapi kaki cecah lantai dah. macam x logik pulak neo 1.6 punya topspeed mcm tu. So, sp2 yg ada pengalaman bole laa share dengan sy, harap otai2 neo dapat bantu sy. Terima kasih, Salam 1 Neo
es2611
951
175
1,543
Re: Perlukan otai2 neo untuk membantu
cuba RON100 drpd PETRON 15 Jan ni. hehe.
Veloc
3,234
991
Sabah
So what you expect is the normal top speed for neo auto? 250?
Zack Zikry
From Facebook
14
29
Selangor
www.facebook.com
Atleast 170-180. Just same in brochure
---------- Post added at 10:20 PM ---------- 6 hour anti-bump limit - Previous post was at 10:17 PM ----------
At least 170-180. Just same in brochure
6UE5t
6,000 RPM
6,756
1,300
How is your car condition, fully standard or already using big rims and/or have heavy speaker box inside? Try testing when the fuel level is below half to make it lighter.
Would not help if the engine doesn't need such high RON requirement, it'll be just a waste of money.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Looks like the engine is a bit tired.
Just like 6UE5t point in his question, the condition plays a major role.
It should be able to clock at least 170kmh on gps if everything is well.
Zack Zikry
From Facebook
14
29
Selangor
www.facebook.com
Fully standard.
What should i do?
Any recommendations?
---------- Post added at 02:26 AM ---------- 6 hour anti-bump limit - Previous post was at 02:24 AM ----------
:( yeahh it should be, but what should i do? Someone told me I should do PDT tune. Should i? Cause only pdt tune can tune up vdo siemens computer box
Try locking in 3rd and drive. See can reach red line or not. If can, then only switch to D and see if you can go higher speed.....
---------- Post added at 09:56 AM ---------- 6 hour anti-bump limit - Previous post was at 09:54 AM ----------
Yup, agree that the engine do not require higher Ron will be a waste of money....:driver:
Waiora_ProTuner
619
221
1,543
mine can only reach around 160km/h, stock standard under 10,000km....
after some mod can only reach 190km/h...
130hp, big speaker box, 16 inch rims and leather interior...
similar to Neo CPS...
i bet changing to manual and reduce weight can go over 210km/h...
ken yeang
6,000 RPM
6,617
1,327
a standard neo like TS's car, will be floaty when doing 150.....so, I'll be careful driving such speed or higher....
Waiora_ProTuner
619
221
1,543
True that...can't just bought a car and test its top speed...
RON97 definetely helps...they develop the engine during that time...its show some difference at top end on dyno...
Remove all unnecessary things (reduce weight)
check tyre pressure (a bit high can be good)
clean all filters
change all oils (engine and ATF)
reset ecu
clean cars inside out
do some high speed/rpm runs (clean of carbons)
find flat route (bandar saujana putra to KLIA, kesas klang area, guthrie (not flat but empty), mex)
wind up windows
off aircond
and go...
HKS or BLITZ blow-off valve ?? which one is better ?? their price ?? or you guys got other to recommend?? hehe ... have no idea bout it ... :D
