if i dont have oven...what else i can use to heat it down?Here is Quick DIY to get the Engine Bay Looking Great
This Applies to Engine Covers too and should cost no more than Some Time and Rm50.oo For the Paint
WHAT YOU'LL NEED:
1. 1 x tin of VHT(Very High Temperature) Wrinkle Paint
2. 1 x Bottle of Clean Green(Degreaser/Detergent)
3. 1 x Roll of Toilet Paper
4. 1 x Hairdryer/Heatgun
5. 1 x Oven
6. Baking Gloves
WHAT YOU'LL NEED TO DO:
1. clean the VC with a strong detergant to remove all oil Residue/Paint will not bond to an oily surface
2. clean the VC with a strong detergant (Very IMPORTANT)
3. clean the VC with a strong detergant (Very IMPORTANT)
4. clean the VC with a strong detergant (Very IMPORTANT)
( Make Sure you Work in a clean / Dust free Enviroment to achieve maximum effect )
5. rinse in very hot water & wrap in a towel for quick drying or Blow dry with Hairdryer
6. tape/plug up the holes
7. tape/plug up your nose
8. spray very evenly in 1 direction holding the tin about 30cm from the Valve Cover
9. spray each coat in a different direction, the paint is very powdery so don't worry if you don't see the first few coats (Allow 5 / 10 Mins Drying time between each coat , Not Neccesary but would Recommend this Step)
10. after every 5 odd coats, warm up the VC using a hairdryer or heatgun
11. repeat this process until the tin is empty, it should be about 20 odd coats
12. for the guys that need to use the car daily, put the VC in the oven at 120C for about an hour & leave overnight (WARNING - BAKING THE VC FOR TOO LONG WILL CAUSE THE PAINT TO DARKEN) If the Car is not a Daily Driver allow one or two days to Air Dry Fully
13. tape up the areas surrounding the "DOHC VTEC" & sand down carefully using a block wrapped in water paper taking care not to damage the new paint finish
The End Result is Awesome and will make you want to show off your Engine Bay :
:proud::proud::proud::proud::proud::proud::proud::proud::proud::proud::proud::proud::proud:
ANY questions Feel free to ask
if i dont have a hoven can i use a hair dryer...or heat gun...or engine heat..please need a help please.....Here is Quick DIY to get the Engine Bay Looking Great
WHAT YOU'LL NEED:
5. 1 x Oven
6. Baking Gloves
