DIY install oil cooler with relocate oil filter
me2kimi
717
276
1,563
Puchong
Hi all DIYers,
This is my latest DIY project. I'm too lazy to write it here. But you can visit my BLOG for more stories and picture.
Hi all DIYers,
in my opinion, u need to add another supporting bracket...
afraid in long term the single bracket would be broken due to vibration (metal fatigue)
me2kimi
717
276
1,563
Puchong
Thanks bro for the opinion. Will try to make extra bracket to it
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
just a thought, your location is very near the exhaust manifold. How is the oil temp showing up.
ColdPlay
288
112
Exactly! The oil filter may turn much hotter than in its original position.
Any cooler or relocation of engine parts should be install away from the exhaust manifold
as that is where most heat are generated.
Also, why put the filter so high? The oil pressure not affected meh? And upside down, doesn't that make it a mess to cleanup everytime you remove the filter?
Was about to say the same thing. Sideways already bad enough, upside down will be more messy.
Yah! pressure will be affected....
me2kimi
717
276
1,563
Puchong
will the metal holder knock the exhaust cover making noise ??
Nop, actually the adapter is not moving at all. The bottom fitting (which connect the adapter) are fix between it. So the bracket is just for extra holder.
The original location of the oil filter are already just beside an extractor. I don't use any gauge.
It seem that the is the best location for the relocate oil filter. Or else I need to remove washer tank and relocate oil filter to that location. The tips to did not mess up with oil when replace oil filter is replace at when engine is cold. With this kind of position, it will be very little oil left inside the oil filter.
Pressure will be affected once oil cooler are installed. It is because of inside oil cooler there is a fins in the oil cooler tube. So, it will create more restriction inside oil cooler itself.
TitanRev
Mar 3, 2005
8,180
3,678
me2kimi, thanks for the info. I believe the oil left in the oil filter wont be much as the oil inside the filter will get pull back to the oil sump by gravity.
That is actually not good. This means every morning there is a delay ii the oil circulating.
When you do oil change, the first time you start, engine oil got to fill the filter first before it can circulate. If you look at the oil pressure light on the dash it takes a few seconds before the lights goes off. Subsequent starts the lights goes off immediately because there is already oil in the filter.
If the oil drains back every time then every morning it got to fill the filter first....
me2kimi
717
276
1,563
Puchong
Bro vr2turbo, yes that is what happening on every morning. But I believe oil left inside the head itselft is sufficient until oil reach the head.
BTW, previously (before install oil cooler and relocator) I've always replace oil and oil filter when engine are cold. What I saw is there are also few oil left inside the oil filter.
Currently, on morning start does the oil light goes off fast?
me2kimi
717
276
1,563
Puchong
light goes off around 1 second after engine started. Just a bit longer than before but not too long.
This is what I got from Wiki
Valves
Most pressurized lubrication systems incorporate an overpressure relief valve to allow oil to bypass the filter if its flow restriction is excessive, to protect the engine from oil starvation. Filter bypass may occur if the filter is clogged or the oil is thickened by cold weather. The overpressure relief valve is frequently incorporated into the oil filter. Filters mounted such that oil tends to drain from them usually incorporate an anti-drainback valve to hold oil in the filter after the engine (or other lubrication system) is shut down. This is done to avoid a delay in oil pressure buildup once the system is restarted; without an anti-drainback valve, pressurized oil would have to fill the filter before travelling onward to the engine's working parts. This situation can cause premature wear of moving parts due to initial lack of oil.
Just sharing, because am no expert either......:rolleyes:
devilz 78
376
9
kuala lumpur
Hey I need to learn this, your engine is blacktop as well? hows the oil pressure? did u install oil pressure gauge to monitor?
Anyone knows when Perodua is likely to upgrade or replace the Viva ? I read somewhere that Viva may be replaced in late 2013.
