Grounding Installation - DIY Tips
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
Hi,
just finished install grounding to my ride and would like to share my installation steps/guide/tips with you guys.
tools : 10mm and 12mm wrench, cutter.
material : 10mm nut x 2, 10mm bolt x 2, 12mm nut x 1, Hot Earth gold grounding and zaptor platinum volt stabilizer
ground point : 1 x firewall, 1 x engine block, 1 x alternator, 1 x side panel(RH), 1 x engine block - Frt panel.
firewall
to install the grounding to this point, i hv chosen the nearest point...its d fuse box there. remove the fuse box bracket bolt-10mm and install the grounding cable there.
Engine block
the engine block hv 2 earth cables(small), 1 joint both together with my grounding :)
Alternator
alternator got 2 options to install the grounding, either thru the 10mm long bolt or the 12mm side bolt. in my case, i installed to the side with 12mm nut to secure it. easier
Side chassis (rh)
this is quite easy job, just remove the 10mm bolt tat secure the grounding and install together.
front panel - engine block
myvi 1.3 originally comes wit this grounding but a tiny cable, i replaced it wit Hot Earth cable only
more photos here :
http://huakenny.fotopic.net/c1713517.html
frank118
435
24
Yeah man...so thick like it is enough to ground a building!!!
Dont even see the 5 wires...and the zaptor looks so big too...you cusomed it for yourself???
Hahaha.
frank118
435
24
Walao! RM6XX!! Did you feel any difference after the installation?
Also read that the areas where you attach the ground wires to tend to corrode and rust faster any prevention to that?
Jun 20, 2009
4
OMG.. looks like snake is in the engine~! :slug:
Bump: so expensive.. y not install mega raizin? no good? :hmmmm:
na_power
1,412
How come u compare pivot grounding with Hot Earth Grounding? Huhuhuhu Hot Earth & Hot Inazma are own its own class. Both by Sun Auto.
