I'll try to replace QM3 first.
Sanken- STA413A
Panasonic- PU4127
Thanks e-tech![/QUOTE
Yeah.... That is the part you should change first...
Do a simple confirmation.... go borrow a known good ecu and test and seehi Sifus..
Suspected got problem with my ECU.CEL code 14(Idle Valve) and 6(Coolant)and sometime with 7(TPS)with rough idle at 1500 to 2000RPM
Tried to change all 3 sensor but ECU still throwing similar CEL.
Anything need to check on the ECU.?BTW i nvr do anything on the ECU even change the Cap.ECU already more then 10 years.
Email me s good picture and I will try to help youhi E-Tech..
I'm using P30 manual B16A.Change all the caps but still have CEL 14...Idle a bit smooth now..
anything else need to check?Which IC or transistor releated to CEL 14?
Thx in advance..
Try Ic109... Tqhi etech..
ecu evo2364 no cut off for aircond fan.. on ignition the fan already switched on. no burns and copper damage inside ecu.. any ideas what to check?
If for your car meaning 1 pc of those parts, I think I canhi E-tech
do u know where to get STA413A and TA8903sn.. just to standby in case..something bad happen..hehe :)
Hi Etech,
Gd job for posting and sharing...Iv readng ur post and others quite sometime, learning something that MOST MALAYSIAN KEDEKUT to share. Most chipper (as i call them...hehe..the 1 makes money chipping ur ecu) refuse to share knowledge as they gonna BANKRAP if they help 1 or 2 people who wish to DIY. Neeehh...leave them alone, gonna need ur advice.
I'm working on P27 ecu 02D01720-1500 non vtech. Crack open the casing already, went shopping a few elect part
1. can i use HD74HC373P for IC4
2. can i use 50v caps instead of 35v
3. can i use 1N4001 1A 50v for D11
4. can i use C144 ESK for Q26
5. Problem getting IC14 515 High Side Switch, can i get from u
6. i notice levin818 posting about O2 sensor (all P27 ecu )
So many can r...Thanks..hehe
