DIY Honda ECU Repairs- P30 P08 P27
levin818
1,260
321
3,183
Shah Alam
Hi Levin...
You missing a resistor for O2 function.
Original P27 do not support it.
pM for answer.....
Tq....
P/s too many copycat here that post copied info and pictures direct to their blogs!!!
TQVM! Just check an ori P27 ECU and found that no O2 support components there... So have to recall back the ECU for modification! Tks man!
The moment you start this topic, you can't stop the copy cat... unless you limit the information sharing to the ppl that you know only.
IMO, some information is too dangerous to share. For eg, if a DIY enthusiasm successfully repair their ECU according to your info, that is fine. But if he failed, he may drove his car to the drain... :biggrin: So for critical item like ECU, information sharing got to be very careful.
E-Tech
1,115
256
3,183
Johor
Please diy at own risk!!!
Service can be provided if you value ur car.... :-)
E-Tech
1,115
256
3,183
Johor
The the chance to mount the newest version of Hondata 300 V2 on a P28 ecu.
Here are the pictures..... It is a RED Hondata brd.
Finland
Hi,
Hello to everyone, first post :wavey:
Would like to have some help from E-Tech with this ecu I have got, it has solid cel.
But to replace the ordinary parts which brake down, this ecu seems to have some parts desoldered, maybe that is the problem. I`ll put some pics here.
Thanks for any help!!!
Jul 28, 2012
4
Car: Honda Civic EF
Engine: Carb to D15B vtec
ECU: P08 JDM rechipped box and P08 JDM stock box
Wirings: Okay except that i recently discovererd that the car has no main relay - Fuel Pump is directly connected to the ignition switch/key
Car is running fine. No CEL or whatsoever. Recently, I borrowed my friends Rechipped/Programmable ECU to test the CROME's launch control feature in my car. I just plugged in my friend's ECU and viola! my car runs aggressively and the launch is soooo cool!
Here's the bad thing happened, after the test, my friend plugged in the Programmable P08 back to his car and suddenly his car wont start! :( :O my friend borrowed my Stock P08 ECU and then tested it in his car, same scenario happened, his car also did not start! :( we borrowed a stock ECU from another friend and my friend's car started and ran fine. I think both ECUs are now broken. (my stock p08 and the programmable p08 ecu of my friend) :(
Troubleshooting1: (friends car): Using the recently working Programmable P08 and my Stock P08 box
- No CEL
- ECU startup ok (check engine turns on then off)
- The main relay is not clicking
- The fuel pump is not priming (checked the fuel rail no gas)
- Checked the iginition (there is spark in the plugs - distributor)
- Car won't start
Troubleshooting2: (friends car): another p08 ECU from another car
- No issues
- Car runs fine.
Another test: My friend's programmable P08 ECU and the stock P08 ECU when plugged in my car is working perfectly fine. It is just that both ECUs now wont let his car start. We also tested both ECUs to other car and the same scenario happened.
Conclusion: The stock P08 ECU and the programmable P08 ecu is Broken :( It is only working in my car! and these two ECUs are not working to other normal cars.
Findings: My Civic EF has no main relay! I guess the wires are directly connected to the ignition switch. Fuel pump is bypassed :-S
Solution: Restore the wirings back to original. Install a main relay.
Now, my Big Question is: How do i fix broken ECUs, what components do i need to check and replace? When i look at the programmable p08 box of my friend, i cannot see a trace that is broken or a component that is damaged. I need to fix my friend's ECU. Please help. :adore:
E-Tech
1,115
256
3,183
Johor
definately your previous wiring has caused the component related to original fuel pump to blow...
ur car it directly wired to fuel pump and always on even if engine not running...tat is dangerous
you need me to fix the ecu it....let me know....
Localhost
1,503
hi Sifus..
Suspected got problem with my ECU.CEL code 14(Idle Valve) and 6(Coolant)and sometime with 7(TPS)with rough idle at 1500 to 2000RPM
Tried to change all 3 sensor but ECU still throwing similar CEL.
Anything need to check on the ECU.?BTW i nvr do anything on the ECU even change the Cap.ECU already more then 10 years.
E-Tech
1,115
256
3,183
Johor
hi Sifus..
Do a simple confirmation.... go borrow a known good ecu and test and see
the results...
Localhost
1,503
hi E-Tech..
I'm using P30 manual B16A.Change all the caps but still have CEL 14...Idle a bit smooth now..
anything else need to check?Which IC or transistor releated to CEL 14?
Thx in advance..
E-Tech
1,115
256
3,183
Johor
hi E-Tech..
Thx in advance..
Email me s good picture and I will try to help you
Out..
Localhost
1,503
Finally my ecu alive...1 Old civic saved...thx u so much e-tech for ur guide and help...need time and check everthing carefully ..for those havent change caps...pls do so before to late
Sep 3, 2012
los angeles
E tech i need your help. I have a 98 civic ex manual. Vtec used to work about 1 year ago and just stopped working. i did all the required tests to it and finally did the ecu test. I checked for voltage at the vtec solenoid wire and the vtec oil pressure switch wire and no voltage was produced above 5500 rpm on either. so i can confirm that the ecu is the cause. But i have no clue where to look at the ecu motherboard. I think 1c19 is a piece that controls vtec, not sure. Please let me know what to do and what to check. its a p2p a34 ecu all caps appear good. Everything else on ecu works no Cel just the vtec. also where can i find a diagram on ecu's?
zamiex
443
11
hi etech..
ecu evo2364 no cut off for aircond fan.. on ignition the fan already switched on. no burns and copper damage inside ecu.. any ideas what to check?
I have purchased three of these systems and they are all not working right in winter. They all worked fine this summer, but now that the temperature is down to 10F two of the systems are not starting. They try to start, then the alarm goes off-display on remote shows hood pin. Also all three are not auto locking when driving and unlocking after parking anymore. They used to.
Several other people have the exact same problem. if you search radiostar or carvox you will see many complaints of...
